Thread: 3.0 v6 cdti tc switch
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    Default 3.0 v6 cdti tc switch
    i know the tc switch thread has been flogged to death,i have search the archive and can't find anywhere if anyone with a pre-facelift 3.0 v6 cdti has tried the switch and more importantly if it works.
    Neil, as yours is a Design V6 it will have ESP+ (Electronic Stability Programme). I thought that meant that it would have had the TC/ESP switch fitted as standard.
    Some of the cars that should have had the switch as standard at the factory, never had them fitted. There was a Field Remedy on it and the switch (and loom if necessary) was fitted FOC by the dealer (if the car was inside warranty) - although it seems to only relate to the GSis and of Sep 2003 this was rectified in production.
    So, not really any clearer in your case. It will definitely have ESP+, but it's still 50:50 if the switch will work. I'm assuming you have the blue plug? For a tenner you may as well give it a go.
    Don't forget, if it does work you're not just turning off TC, you're turning off the ESP+ system, so careful on those corners! lol
    Oct 2007
    Back in Belfast!!!!
    it is a design no switch there when i got the car but plug is there.
    thanks for the info D will probably just give it a go and watch out for them corners if it works as you say its not a lot of money.
    And if not, there'll be plenty of people on here who'll want it...
    Me for one..
    Aug 2007
    tamworth
    Hi i Hav just fitted said switch into said blue socket on my 03 3.2v6 elite an it doesent seem to do any thing would it help hacing it plugged into tec2?
    Here, there and every where!
    Nope! If it doesn't switch the T/C off and the warning triangle on the dash does not light up when pressed then Tech 2 will not get it working
  1. Small 12v Auto circuit for on/off switch for PDC switch
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 23:00
  2. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  3. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  4. TC Switch on V6 CDTi
    By willc01 in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2006, 13:04
