Results 1 to 10 of 11
Thread: Rear fog lights
    Regular Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    Default Rear fog lights
    Do you guys no if the vectra has one or two rear fog lights?
    I was just wondering bcos last night it was foggy so i put my rear fog light on and the drivers side came on then look at the passengers side and saw a bulb in the same place not working?its the bulb between the reverse light and the side light on the passengers rear light any ideas??
    Jul 2006
    Been covered loads of times.
    2 bulbs, only 1 works. EU requirement, it's to make it more obvious that it's a foglight and not a brake light. The second bulb is a spare, there's no wiring for it.
    HTH
    Regular Member EURO G's Avatar
    n ireland
    think they have two rear fogs directly above or below the side lights
    New Member Bumblebee71's Avatar
    Nov 2007
    Mexicali, BC, Mexico
    What Parapaul says is true, there are 2 fog lights but only 1 works, second one is spare, this can be seen on user manual.
    May 2007
    Norwich
    Engine : 2.2 z22se
    Thanks lads, i wasnt sure,it would look better if both worked!!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    IMO, rear fogs are more dangerous than they are worth, as a huge proportion of people don't know how to use them properly, causing rear dazzle and not seeing the intensity change when brake lights come on. I have seen muppets driving with foglights on, with cars behind them or in about a mile visibility completely unaware that they are ***** who should read the highway code for the correct usage of said lights.
    Really is a bugbear of mine.
    Regular Member simac's Avatar
    Wirral
    Quote Originally Posted by Ste View Post
    Really ? would never have guessed LOL
    Well, I tend to agree. There are far too many drivers using them when there is no need, front ones too for that matter.
    Leeds/Dresden
    Its for lhd models.
    May 2007
    West Yorkshire
    Ditto, no excuse on most cars as the lights are reset every time the ignition is turned off, the front fog brigade are more of a wind up though imo.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    If you would like both rear high intensity to function just run a wire from the correct h/i contact in the conector block in the one that does work under the boot floor to the other lamp housing conector block hi contact, and then there were two!!!
  1. Led Side Lights Fitted & 2 Rear Fog Lights
    By wardy23 in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2012, 23:16
  2. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
