Results 1 to 10 of 14
Thread: Cdr 2005
    Regular Member Perry's Avatar
    Watford Herts
    Default Cdr 2005
    I have one of these that seems to be developing a fault as in the cd starts to jump and not read discs etc.
    Being different I would like to keep to Vx head unit what are the better alternatives for this model.
    I know they do a 4 discs one with a tape unit is this better ?
    As my car is half canbus I assume I will need a code only for a new headunit.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Think you might need the screen that came with the newer HU (CDR2006) as they are locked together. The HU will work but will not display on the screen. On the other hand you can get a new screen from VX but that will then need to be linked to the HU.
    Watford Herts
    They do a CCR2006 that has a four disc and tape unit this is the one I meant, is it better than the CDR2005, I know tech yes as it has 4 discs, but any improvement in sound ?
    This sort..........
    Vehicle : SRi
    Mileage : 137000
    Never had the pleasure myself but I remember reading a thread basically saying the 2006 is more powerful than our 2005 which will translate into better quality sound.
    Watford Herts
    Ok thanks
    Regular Member graham a's Avatar
    hull
    had a cdr 2005 in my last vec c,then replaced it with a ccr2006.must say,i thought it did sound better than the cdr 2005.also,did not have to change the screen
    Watford Herts
    Quote Originally Posted by graham a View Post
    That'a the bit I like to hear
    [Ex]Admin Duncan's Avatar
    As above, the CCR2006 (what's in mine) is a much better unit than the CDR2005 and no need to change the screen. I 'think' you need to change the cage as well to take the CCR2006 as I 'think' the connectors on the back are in a different place. Not 100% sure, but just seemed to recall reading it somewhere. Graham a would, I'd think, be able to confirm that, or whether I'm talking rubbish! lol
    Watford Herts
    Thanks D, never gave the cage a thought!!
    I await further confirmation
    hull
    the plugs are identical on the back of both cages.the only difference with both cages is that the cdr 2005 has a plate in the middle (which i removed my self) which supports the top part of the cdr 2005.if you do not want to bash the cage with a hammer,just get one from the stealers
  1. CDR 2005 Aux mod
    By Domchapp in forum Styling
    Last Post: 20th February 2015, 14:19
  2. 2005 2.2 radiator to fit a 2005 1.9 cdti 120bhp
    By IRvectra786 in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 08:59
  3. Cdr 2005
    By Das in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2010, 01:44
  4. Cdr 2005
    By penfold2000 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2008, 21:33
change cdr 2005
