Thread: Removing automatic windscreen wipers?!?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Removing automatic windscreen wipers?!?
    Hi,
    Is it possible to remove the automatic windscreen wipers sensor along with the interior rear view automatic dipping mirror/ambiente light and refit it in another Vectra C?
    Because if it is thats whats going to happen.
    in a word.. No..not possible really..
    11 Post(s)
    I thought it was possible to fit the auto dip mirror?
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    The mirrors have different mounting brackets to the windscreen IIRC depending if you have a Rain Sensor or not. Although they might physicly fit, the rain sensor models have brackets built onto the mirror to hold the casing over the sensor. However, I havent looked to see if this part of the mirror is detatchable. (Just don't pull the ball joint out, as they dont tend to go back in without breaking the glass!)
    Obviously, if you have a Rain Sensor Windscreen (which has the mountings for the sensor to clip to), then yes, you can just swap over. However, if you have a windscreen without a rain sensor, then obviously, you can't.
    Though, if you really wanted to, you could replace the Windscreen with the appropiate one, but of the top of my head they are about £250-£300+.
  1. automatic rain sensor wipers and lights
    By ADAM123 in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2008, 17:20
  2. automatic rain sensor wipers and lights
    Last Post: 30th May 2008, 17:10
  3. Windscreen Wipers
    By macdad in forum Bodywork & Interior
    Last Post: 4th February 2008, 22:22
  4. Automatic Wipers?
    By pauls898 in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2006, 20:20
  5. Automatic rear wipers
    By CBR600FV in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2006, 22:17
