Results 1 to 10 of 17
Thread: True or false regarding new engines?
    Denmark
    Default True or false regarding new engines?
    Hiya...
    I', gettin my vectra 2.0 turbo tomorrow and since this is my first brandnew car... I have a question.....
    I've always heard alot bout having to take the first 1000 km's slow untill the engine is used to the heat n pressure.
    But on the other hand I've heard alot of people say that it isnt an issue anymore thanks to new technology, testing, materials and what not...
    So any oppinions on this? Before i go wreck my new engine..
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    Drive it like you stole it!! Never ever had a problem with any car like this.
    Although I always have a wee oil change after 1000 miles, other than that drive as normal.
    Ashington, Northumberland
    Quote Originally Posted by Mrsan View Post
    Hiya...
    Not really an issue nowadays. Enjoy
    Jan 2008
    Glasgow
    Not really sure with the vectra,but when i got my subaru impreza sti out the wrapper,i was imformed that for the first 1000 miles that i was to break it in gently not above 4000 rpm mixed driving due to the ultra thin oil,then once the 1000 mile service was done it was all hammer and tongs!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I had a new lump fitted to my vec last year and was told to drive easy for the first 1000k by VX.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Not generally an issue these days. The VX manual does state that for the first 1000 kilometres do not exceed 75&#37; of the total output of the engine, which in the case of the 2.0T is 75% of 143 mph, in top speed terms,so unless you are an utter raving lunatic speed freak, you won't have a problem there.
    It also advises against too much unnecessarily harsh acceleration during the same period, particularly in the lower gears. A modicum of common sense is all that's needed. I seem to remember reading somewhere that continually over revving the engine very early in a car's life can do far more damage than doing so after the engine has bedded in.
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Personally I think you would probably do more damage to the gearbox oil by thrashing it from new than you will do to the engine.
    Remember, you change the engine oil regularly, the gearbox though, never!.
    There are a lot of sharp edges on all those teeth which just love to shear the long chain molecules.
    Once the gearbox has worn in a little, the oil is better at seperating the contact points of the teeth.
    I once fitted a remanufactured gearbox to my CavMkII and drove it like I always did! for about a hundered miles. Boy did that gearbox get toasty!, may well have damaged the oils properties. Changed it and took it easy for the next 1000 or so. Ran cool and bedded in nicely.
    Then proceeded to be thrashed. Never got as hot as the first thrashing.
    Hope this helps.
    grimsby
    i pdi new cars for 12 year day in day out for audi group and trust me the 10 mile road test i do in them is enough to run any car in.redline in every gear
    grimsby
    well first 4
    Jan 2008
    Glasgow
    Quote Originally Posted by learoy69 View Post
    well first 4
    But did you own them?
  1. Conkers stop spiders - True or False?
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 8th September 2010, 13:29
  2. True or false...
    By Harry in forum General Chat
    Last Post: 1st February 2008, 14:24
  3. True or False.......
    By T4M in forum General Chat
    Last Post: 4th January 2008, 20:24
  4. 3.2 Engines
    By Richard in forum Petrol Engine related
    Last Post: 13th February 2007, 08:32
  5. true or false....
    By Harry in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2006, 17:25
