Thread: interior light fault. help!!!
    Regular Member vecsxi's Avatar
    Nov 2005
    liverpool
    Default interior light fault. help!!!
    Hi all. just got home from work and wife has just noticed that interior lamp
    did not come on when she opened the door.
    it also wont come on when you unlock the car
    but will work when you press the button
    has anyone ever come across this fault before? would be grateful for any help
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Dont the interior lamps have 3 seperate bulbs? One for left hand side switch, one for right hand side switch, and one in the middle which is turned on by door opening
    Nov 2005
    liverpool
    think thats for ones with reading lamps but mine only has basic unit with one button its very strange!!!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    have you checked the bulb or fuse
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    is there a 3 position switch? One to turn off altogether, one for on and one for courtesy functions?
    Nov 2005
    liverpool
    no its just got the basic push on or off switch
    but its strange because when you push the switch it works
    but when you open any door it dosn't
    Regular Member JonV6's Avatar
    Cardiff
    Have you got your lights sorted yet? Sounds like the same problem I have. Spoke to VX today, they think the light control unit is knackered. Started the thread below on the subject....
    http://forum.vectra-c.com/showthread.php?t=42613
    Nov 2005
    liverpool
    have been told to book car in to dealer and let them have a look as its still under warranty. have a sneaking suspicion that when i pulled the headlining down to see if rear lamp wiring was there i may have disturbed something lol
    but wont tell them that.
    Regular Member Leviathan's Avatar
    Middlesbrough, Cleveland
    Actuator switch on the door must be faulty. Probably a couple of quid to replace.
    when you have the door open - does the "Door Open" warning display?
  1. Interior light fault
    By rob warrington in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2011, 10:54
  2. URGENT:Glovebox Light/Interior Light Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 09:13
  3. Interior light fault
    By pritch in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2010, 12:39
  4. interior vent fan fault
    By toofarfalls in forum Bodywork & Interior
    Last Post: 6th October 2008, 21:14
  5. interior light fault
    By vecsxi in forum Electrical & ICE (including SatNav)
    Last Post: 12th February 2008, 20:22
