Thread: metal sound under car
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default metal sound under car
    hi i have come across what i can only described as a metal to metal vibration under the front of the car which sounds like its coming just in front of the front doors. it only happens when the car is in low revs such as pulling off so about 1500 to 2000 rpm. could it be the cat inside breaking up? are there any other signs fot the cat failing i should look for? thanks
    metal on metal?..doubt it's the cat...i wonder if one of the heatsheilds on the downpipes is loose?...have you had it checked with the car up in the air?..
    Feb 2007
    hi no i am going to do that tommorow. what made me think it was the cat was ive had a very poor petrol consumption and everything else has been checked by the main stealers!! i know its a 3.2 but i used to get around 27mpg now its about 22 on the same run. ive also been told if its the cat when the bits break up inside thats the kind of noise you get but i could be wrong!!!
    shouldn't worry.. this cold weather has killed our consumption figures too....
    when it's up in the air you'll be able to hear where the vibrations are coming from..put a leather glove on and you'll be able to hold the pipe and see if you can stop it rattling as well..
    if the cat is shot, get a sportscat..much much cheaper than a genuine item..
    Feb 2007
    will do that tommorrow cheers. what kind of price is an original cat compared to sports one? would it still pass an mot with the other one on?
    a sportscat will still get you through the MOT no worries...they cost around £200.. a VX one runs around £400-£600..
    Feb 2007
    oh my god did not realise they are so dear! if it has gone i think it will be the sports one!! any idea where i could get one?
    several online retailers advertise in total vauxhall magazine..
    Regular Member marcdale's Avatar
    May 2006
    Bristol
    I have a similar noise on my mine when i'm pulling away hard. The only thing I could see that was obviously is the heat shields on the bottom of the spare wheel well have rusted through the mounts because it's just a cheapy bit of thin metal.
    When I get on to it i'm just going to undo the bolts and put some big washers on to hold the heat shields back up.
    Regular Member Ant S's Avatar
    Ashington
    I had that problem on my 1.8 and it turned out to be the heat shield which is around about underneath the gear lever or handbrake area - it had actually fallen off the car and got wedged over the exhaust. The AA put it back on as i was 200 miles from home - its made of a very thin and bendy metal - hopefully thats waht it is as the CAt sounds expensive mate.
    Ant
  1. Sounds like metal-to-metal from the rear.
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 2nd April 2014, 12:01
  2. Vectra-B brakes sound like metal to metal
    Last Post: 4th December 2011, 14:42
  3. Vectra c clucking from drivers side wheel (cracking metal sound)??
    By smithonline in forum Suspension, Wheels & Brakes
    Last Post: 25th September 2011, 11:28
  4. metal sound?
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2010, 12:04
  5. Metal like creaking sound from the back of the car
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 17th September 2008, 10:23
