Page 1 of 9 123 ... LastLast
Results 1 to 10 of 82
Thread: engine misfire 30ltr cdti
    Regular Member 30ltr nutter's Avatar
    dunstable
    Default engine misfire 30ltr cdti
    hi i have a 2005 30cdti when lightly using throttle at between 40-50 mph on a slight incline it feels like the engine is misfiring it rides through it and if u apply full throttle it rides through it has any one had this fault before and if so what was the cause and cure many thanks 30ltr nutter
    getting any fault lights or codes?..
    dunstable
    no no lights on at all it has just had hp pump fitted due to a noisey pump but was doing the misfire before pump was fitted so i thought it was down too the pump but it is still misfiring thats wat it feels like
    Regular Member v6diesel's Avatar
    Southampton
    Mine is similar, though it has a pronounced misfire on tickover as well as at part throttle...
    Booked back in at the dealers soon to get it looked at again. Last time they did a software update which stopped the spanner light coming on all the time but didnt cure the mis-fire
    dunstable
    hi m8 i know that they have just updated the software when they did the pump i spoke to the dealers and iam going to take it into them next week so i can show them what it does because if i leave it for them to test they will just say no fault found and it runs out of warranty on 17/3/08 but they have agreed to extend that into the 4th year the clutch also dont clear when cold it drags ad grates on gear change it gets better with use so i want them to fix any faults before next month
    Full Member
    Bristol
    Default Missfire
    Can you tell me what you fault was in the end.
    dunstable
    hi they have never solved it the vec was ment to go back in the stealers but we needed it so ive got to book it back in but to a different stealer
    Southampton
    Mine blew the engine
    Its in having a rebuild at the moment
    Full Member
    Bristol
    Default missfire
    Does you car missfire or hesitate if you are stationary. Press throttle down and hold it in the 1500 to 2000 and see if it does it then. I would be intrested to know as mine does.
    dunstable
    i will try when i get a chance just got in from work the wife uses the vec at the moment i have noticed it smokes bad on hard acceloration thats why its going back in the stealers i think its going to be a injector fault the misfire i have is on light throttle application at about 40 mph the only way to stop it is to drop gears it does ride through it when it does smoke u cant see the car behind u
  1. FYI engine misfire / spluttering 3.2
    By DSmiddy in forum Engine & Drivetrain
    Last Post: 4th December 2013, 18:56
  2. turbo boost fault 30ltr cdti
    By 30ltr nutter in forum Engine & Drivetrain
    Last Post: 10th May 2011, 00:28
  3. Vectra 1.9 CDTI SRI Nav Engine Misfire issue
    By Joe1 in forum Engine & Drivetrain
    Last Post: 16th September 2009, 10:14
  4. Engine misfire on 3.2 v6
    By STEVE S in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2008, 12:00
  5. engine misfire?
    By littlesxi in forum Diesel Engine related
    Last Post: 1st March 2008, 01:13
saab 9-5 limp mode juddering
3.0cdti intermittent misfire
vectra c 3.0cdti misfiring but not injectors www.vectra-c.com
