Results 1 to 10 of 15
Thread: K&N Air Filter upgrade, ECU Reset?
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    Default K&N Air Filter upgrade, ECU Reset?
    Just fitted a K&N panel air filter to my 1.9 cdti veccy then proceeded to take the '+' terminal off the battery and my alarm went off! Thought thats what i had 2 do, any1 know what im doing wrong?
    Jan 2008
    South Wales
    Any1?
    Portadown, N.I.
    You have to switch on the ignition, loosen the + terminal, then remove key and within 15 secs, whip off the battery terminal.
    Tim
    Jan 2008
    South Wales
    ill give it a go cheers!
    Jan 2008
    South Wales
    It worked , how long do i leave the + terminal off for now?
    Here, there and every where!
    ....another 10 mins
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Now it will never ever start again
    ONLY JOKING
    Jul 2006
    Anyway, why did you take off the +ve terminal?
    Normal (and safe) practice is to disconnect the -ve....
    Regular Member rmt's Avatar
    Cambridgeshire
    Why do you need to even disconnect it when changing the air filter? (Warning: rmt - minimum knowledge man! )
    Jul 2006
    By disconnecting the battery, you reset the ECU and it can adjust more quickly to the increased airflow through the new filter. You don't need to do it, but it would take the ECU much longer to adapt, and you wouldn't notice the change as quickly.
    HTH
  1. I'd Love a Panel Filter Upgrade but.........
    By robster23 in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2009, 22:26
  2. Air filter intake upgrade
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2008, 16:35
  3. k&n filter and ecu reset ?
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2008, 22:10
  4. air filter upgrade
    By tent01 in forum Introduce yourself.
    Last Post: 13th August 2007, 18:25
