Thread: arghh side light problems warning light
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    Default arghh side light problems warning light
    This is driving me insane.
    Passenger indicator
    Driver indicator
    Driver Side light
    Had all of these come up as warnings past week, all bulbs are working fine, i replaced the indicator for some silver ones, they are all nice and tight othing wrong and they indicate fine.
    Side light seems to work fine but then today i noticed it wasnt, took the cover off the as trying to remove the bulb it lit up again. (so i am presuming the bulb is on the way out OR i have a wiring issue there?
    Indicators though? im well stumped
    sounds like a wiring issue...try wiggling each wire individually... unlikely to be the bulbs as the holder is a tight fit into the lampbowl..had a few with poor internal wiring quality now..
    Aug 2007
    Great Wyrley
    Ok will do, once found what should i do with said wire, bit of soldering or willit need replacing?
    when you find the break, cut out any damaged wire and solder in replacement wire....
    Aug 2007
    Great Wyrley
    Sound cheers for the help,
    Thankfully better weather is here so i can get cracking on it soonish
  1. side light warning help plz
    By rozzer2006 in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2012, 21:36
  2. Problems with Side Light SMD /Led
    By Envy in forum Styling
    Last Post: 17th April 2011, 20:48
  3. Side light problems
    By VX Dan in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2009, 16:50
  4. Possible cure to led side light bulb warning
    By badge25 in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2007, 17:37
  5. Car Pulling To One Side after Warning Light Has Been On
    By willc01 in forum Handling & Braking
    Last Post: 12th October 2006, 21:18
