Thread: Help Neeeded!!
    yorkshire
    Default Help Neeeded!!
    thanks you for reading post just at garage getting 314mm brake kit fitted bought of danboy and all ok apart from he haveing to cut the backing plate behind the disk approx 1inch to fit the bigger calipers is this norm?? also had goodridge brakehose kit to with it was wrong fitment now sorted thanks to danboy and steve at lmf . lmf sent corsa kit by mistake arriveing tomm at garage to fit but the main prblem is he put on the standard brake hoses and the brake pedal is really really spongy he as bleed them and no air trapped he says the standard flexi brake pipes really bulge when useing pedal and the new goodridge hoses should sort this ? am i being thick or is there a special way to bleed them ? he is a good mechanic been going years just dont wont to go tomm its all fited and the brake pedal goes to floor or is spongy thanks guys
    yorkshire
    Default me again
    my car is 07plate 1.9cdti auto sri xp nav if helps thanks again
    yorkshire
    Default ?
    any 1
    yorkshire
    Please Lol!
    right.. so is what he saying is that the brake hoses are bulging?.. this wouldn't be caused by the 314mm kit, just by poor hoses..but i wouldn't expect that on on 07 plated car..
    yorkshire
    Default hi
    he is saying they do bulge but its the vvv spongy brake pedal got me worried he as bleed the brakes and no air there he is a good mechanic used him for years ex merc trained and been set up on own 10yrs hope the goodridge brakes hoses work ? maybe he nicked 1 off the old ones? also as any 1 else had to trim the back bracket to enable the fit? not sure off name but its behind the disk maybe dust cover?
    the cover is the lower ball joint dust sheild..trim it.. it's no big worry.
    the spongy brake pedal....worth a look ( he wouldn't be the first guy to fit them upside down) to check the brake bleed nipple is upwards....did he pressure/vacumn bleed the brakes or pump the brakepedal..???..
    The goodridge hoses are good quality but won't make the pedal 'that' much firmer..if the pedal is soft then it's more fundamental than the hoses unless they have got a huge blister on them..
    yorkshire
    ill ask him tomm to make sure bleed nipple at the top but he is v good and his sons too thought cant wait today now am worried life with cars never dull
    nope.. not if it's modified life's not....
    if the calipers are the right way up, and the hoses are okay then it only leaves the master cylinder..TBH my money is on the calipers being upside down..
    yorkshire
    thanks will check asap in morning thanks love this site and every 1 a big help your rite if brakes are ok i can see a trip to dap for a remap lol
  1. bad ride- help neeeded please
    By hairy31 in forum Suspension, Wheels & Brakes
    Last Post: 23rd October 2010, 22:12
  2. looking to get a zafira gsi !advice neeeded please!
    By myelite150 in forum The 'Off Topic' room
    Last Post: 6th April 2010, 22:59
