Results 1 to 3 of 3
Thread: Fuel Gauge Problem
    Regular Member R13hard's Avatar
    Devon
    Engine : 2.0 Turbo
    Default Fuel Gauge Problem
    I have noticed a strange problem with my Signum,
    When on a slope with the car pointing down hill the fuel gauge drops, i would say quite dramatically, often causing the fuel light to come on, it only takes a few mins for this to happen i.e sat waiting for the lights,
    when the road levels out the fuel gauge gradually shows an increase often as much as the difference between the white lines on the fuel gauge.
    is this normal?
    [Ex]Admin Duncan's Avatar
    Perfectly normal, and the same on many other cars. It's because the float for the fuel tank sender will be at one end of the tank. On a slope the level will drop at one end of the tank and rise in the other - this is what's happening in your case. If you were to be pointing uphill, you'd see that the fuel level rose instead.
    Devon
    Engine : 2.0 Turbo
    Thanks Duncan, I have never noticed it before but can obviously see the logic! D'oh
  1. Fuel gauge problem
    By david.mann8 in forum Electrical & ICE (including SatNav)
    Last Post: 17th June 2012, 21:31
  2. CDTi SRi fuel gauge problem
    By Ade7 in forum Engine & Drivetrain
    Last Post: 8th July 2010, 17:28
  3. newby with factory lpg fuel gauge problem
    By daryl28 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st December 2009, 23:01
  4. Fuel Gauge Problem
    By zipdip in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2008, 07:51
  5. Fuel Gauge problem?
    By Lloydy in forum Electrical & ICE (including SatNav)
    Last Post: 8th September 2007, 21:43
