Results 1 to 10 of 19
Thread: electrician?????
    Regular Member coylo5's Avatar
    May 2007
    n.ireland
    Default electrician?????
    is it possible to take a light switch out and put in a plug socket.
    Regular Member j13hdb's Avatar
    Nottingham
    Am no electrician but if it's good wire that can take the ampage then I see no reason why not!!!
    Cirencester
    Plug or Socket? they dont do both
    May 2007
    n.ireland
    one of these
    Full Member Big Sig's Avatar
    Not really as the light circuit is fused at a much lower amperage than a socket ring main, mainly due to the fact its only got a few 100 watts of lights on it, not kettles. Also if someone didn't know what you had done and took the fuse out for the ring main then worked on your socket, it would still be live. Very bad pratice and a no in my book.
    Regular Member ade's Avatar
    leicestershire
    no can do, lighting is generally wired in either 1mm or 1.5 T&E. power circuits need to be in 2.5 T&E. also the breaker or fuse wont be man enough to take power used by whatever you plug in. Although if you do decide to go down this route anyway please give me a shout after your house burns down and kills your family then i can come and give you a quote to rewire the property. thats if your alive
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    No. Absolutly not. For one, it's against the regs (17th ed now) and it will only be fused at 6A etc, etc. Also, how are you going to turn the lights on/off?
    I also seem to think that BigPete is a sparky. (i was, but not current with the new regs) I'm sure he'll be along to advise..
    leicestershire
    thought that although you can now sit your 17th edition , they dont come into effect till june??? im stillusing my 16th and have been told by my boss that i dont have to be 17th till end of june
    May 2007
    n.ireland
    ok. it wasnt me anyway it was a mate, he'll just have to stop being a skinflint and get a real spark in and wire a proper one. thanks for your relpy's
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Hi Coylo, Dont do it m8.. Regardless of the cable and fuse / mcb sizes the Chances are the switch wont have a neutral, 90% of switches are wired in 3plate wiring which consists of 1 permanent live and 1 switch line, Sometimes you'll find a neutral in switches that have been added on but its still a no no..
    17th edition doesn't come into effect until the 1st July.. I start my update course tomorrow..
    I see things like this day in day out in my line of work as an NICEIC electrical test & inspection engineer, and i fail them everytime..
  1. auto electrician
    By SarahP in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 09:35
  2. Question for an electrician..
    By snapsnap in forum General Chat
    Last Post: 22nd January 2012, 15:23
  3. auto electrician
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 14:56
  4. auto electrician
    By leelfc150 in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2011, 15:23
  5. HELP!! Need an electrician
    By jamesr in forum General Chat
    Last Post: 11th October 2009, 13:47
