Results 1 to 3 of 3
Thread: Armrest
    Regular Member rmt's Avatar
    Cambridgeshire
    Default Armrest
    in my 2003 club vectra the centre armrest is loose... either side of the plastic covering comes off and makes it extremely wobbly. If i click them back in place its a lot less wobbly and is ok, but not perfect - any idea what i need to tighten or check?!?!
    My LS came with no armrest and I fitted one so I know what to do, but you need the torx style socket.
    The panel on the nack of the centre console where the ashtray and cig lighter are pulls off. You can then see the base of the armrest which is a substantial piece of cast aluminium.
    This bolts into a bracket on the floor. Tighten the bolts up and put the cover back.
    It is fairly substantial as you lean on it moving around in the seat.
    Hope this helps.
    Cambridgeshire
    Cool thank you. I'll give that a go! I've got every type of screwdriver etc under the sun, so hopefully it won't be a problem, thanks again.
  1. armrest... will it fit a non armrest model
    By vectraandy in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2010, 23:38
  2. Armrest
    By matt2002 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2009, 22:19
  3. Armrest Help
    By Bethan39 in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2009, 11:44
