Thread: Spanner Light
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Spanner Light
    When driving yesterday i noticed the performance had dipped considerably.Didnt think to much but this morning the same was happening when i noticed the sound of the dump valve had gone. Def no get up n go. Then the spanner light came on.Stopped the car n after a few mins statred fine,light out.
    On way home same thing happened..
    The exhaust sounds louder too..
    Any ideas??
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Update
    Took it tothe staeler i bought it from.After being told the exhauust was fine i then took it to a local exhaust centre(of the stealers choice0 who promptly said both back boxs were breaking up!..Genuine Vauxhall only parts came in at £555.00 for two back boxes!
    Needless to say the stealer said 'aint under warrenty'.So off to my trusty tyre/exhaust centre i go.£300.00 later i gota brand new,custom made stainless cat back system purring away on ma car!!
    When i took the car to the stealers ,after watching the mechanic complete thte fault code reading process, no faults were stored. Hmmmm..maybe taking out the BSR remap n re-installing the original cleared the codes(thanks Justin at BSR UK).
    After the 2nd reset in 5 miles..spanner light comes on again,twice..
    Back to the stealer who tells me its the 'service light'..
    ERR NO!!
    And back to the mechanic i go on friday..
    Question:how easy is it to check the vacum pies from /to the dump valve?
    Question;Should this topic actually be in this section?
    ermm no, so i'll move it....
    remove the front plastic over.. you'll see the vacumn tubing and it's connectors under there, follow them back to the turbo....
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Thanks Gsi3.2..ill check the car when i cleared the ice!
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Thumbs up
    5 minutes after taking the cover off the car was back to perfect..thanks to my sons eyesight!..Turns out one of the tubes from the the end of the dump valve had cum off,simple fix.
    Thanx Gsi3.2
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
