Thread: Sound deadening roof?
    Jul 2006
    Question Sound deadening roof?
    Don't really want to start down the very expensive, laborious and time consuming route of sound deadening but I'm starting to get fed up....
    At certain frequencies, must be a particular bass note because it only happens on some tracks, not others, I get the world's most annoying rattle from somewhere up near the ultrasonic sensors in the roof lining.
    If I gently(ish...) push the sensor, the rattle stops, but I can't very well drive around with my hand pressed against the roof!
    Any suggestions apart from pulling down the headlining and filling the whole lot with expanding foam? I'm really looking for a cheap fix here, the cost of sound deadening a Vec estate would be frightening!!
    Ta
    member of the smoke patrol 230bhp+
    when you say ""If I gently(ish...) push the sensor"" which ones do you mean
    do you mean the sonic sensors
    Jul 2006
    Yep, the little ones just in front of the courtesy light.
    get a small bit of foam to take up the space behind the sensors .
    you may find that it may be the hole light unit and pocket,, it may not be screwed up tight
    always start with the things that cost nothing then move on from there
    Jul 2006
    Does that part just pull out like the sunglasses holder, or is it properly fixed?
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    The ultrasonics just pull down like the sunglasses holder but the light unit is held up by 3 torx screws (t10 I think) undre the light cover.
    Jul 2006
    Regular Member siross's Avatar
    Oct 2007
    in my opinion, if you're serious about your bass then sound deadening should be the first thing you should do. you can get some thick stuff for the roof if you need it but the boot floor and lid would benefit greatly from a bit of brown bread/dynamat/sludge or a combination.
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    Usually those sorts of rattles are down to loose screws or even the cabling vibrating on the panels, just comes down to a bit of trial and error when it comes to sorting it out. Maybe a small bit of dynamat on the roof panel or even the light unit might sort it out? Like I said trial and error!
  1. sound deadening
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2011, 14:50
  2. Best sound deadening?
    By X-men in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2011, 16:02
  3. Sound deadening, N/s done
    By mickydoos in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2010, 09:41
  4. Sound Deadening
    By storey_3000 in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2006, 20:02
