Thread: Found some plugs...
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Default Found some plugs...
    While my bumper was off I found a couple of plugs so thought I'd ask what they are for so maybe I could make use of them...
    This one was under the drivers headlight....
    And this one is attached to my washer bottle...
    Regular Member EURO G's Avatar
    n ireland
    think theyre for headlight washers mate
    The second one will definitely be for the headlight washers. It's for the second pump that you fit to feed those.
    Jun 2006
    Northampton
    Looks like I'll be looking into fitting headlight washers then
    Not too sure if the first plug is anything to do with fog lights as its all connected in with the wiring that goes to the headlight?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Have you fittet headlightwashers yet?
    i have the second plug on your pictures.. can you confirme that they are for the pump? because it dosnt seem to fit here... (plug to small, seems like it). or ?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    the spear one under the head light is for the second horn m8
    and the one by the washer pump is what every one else is saying
    Engine : 2.2 Direct
    humm well is there then a adaptor.. because the pump (part nr. 90 508 709) and that plug. can not fit together....
    Holes in the plug is about 2 mm. holes neede on the pump is 5 mm... or have people just cut of the plug and made there own?
    (humm the other pic wont be put in....)
    Last edited by kenp; 21st March 2008 at 14:00. Reason: trying to show both pictures.
    Regular Member LAV6Y's Avatar
    Oct 2006
    Lisburn, NI
    Quote Originally Posted by glynn View Post
    Second horn???
    Is this fitted when you have the two tone horn??? I always wondered how they done that.
    yep...the horn bolts to a bracket under the headlamp..
    Jan 2006
    Skynet HQ EMEC#5
    The one near the washer bottle could be for low level warning??
  1. Found some spare plugs......
    By Mikey4996 in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2011, 21:19
  2. extra plugs found
    By tony stoney in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2010, 01:05
  3. found these plugs in the boot of car any ideas what they are for?
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2008, 11:07
  4. I've found a car for me.
    By AJA in forum General Chat
    Last Post: 5th November 2007, 14:41
  5. Found this VXR - YAY or NAY?
    By Vectra Singh in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2007, 14:42
