Thread: Remap Options - Not tuning box?
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Default Remap Options - Not tuning box?
    Hi everyone, I have a 1.9 CDTi 150bhp Sri Estate and fitted a tuning module.
    Vastly improves the performance and pleased with it, good value for money. But it has a few ever so minor yet I know they are there type faults.
    - At low revs flooring it sometimes is splutters then fine.
    - Put your foot down, feel the turbo spooling and the car wanting to go, but it has a second delay or 2 and then goes. As if the ECU is holding it back?
    Is there anywhere that can do a bespoke remap to my car without additional add-ons?
    Thanks!
    What box are you running mate? It sounds like the profile needs tweaking on it.
    I've still got turbo lag, but nothing like you've described.
    'Norf Yorks.
    CR1 mate. Have tried changing it with the screw in half turns and it does the same thing.
    Car has no sensor problems whatsover.
    It honestly feels like the car pulling igntion timing then letting it go?
    And if I remove the box, it is fine....
    The box doesn't touch the timing mate. It's only telling the ECU to increase the pressure in the Common Rail. If you bought it from Mike at Diags mate, I'd give him a call?
    'Norf Yorks.
    Ok mate.
    I know it doesn't touch the timing, though the ECU can retard if it senses something wrong?
    Will do.
    Mike will be able to explain what's happening or if he can change the profile for you.
  1. Bsr remap options
    By nikroc in forum Petrol Engine related
    Last Post: 18th February 2013, 15:49
  2. Remap options around Durham
    By GoldenWonder in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2012, 15:26
  3. 2.2 DTi Remap Options?
    By Barrel in forum Diesel Engine related
    Last Post: 8th December 2010, 02:51
  4. Glasgow remap options
    Last Post: 18th April 2010, 20:18
  5. Engine remap, what are my options other than BSR?
    By VXR CDTi in forum Diesel Engine related
    Last Post: 28th October 2008, 19:48
