Thread: vibration ? not simple been in 4 garages cant find fault please help
    Regular Member madmark's Avatar
    great yarmouth
    Angry vibration ? not simple been in 4 garages cant find fault please help
    hello everyone im new to the site and i got a realy good 1 for you all here goes i got a vectra club 2ltr td 03 plate wene i drive it it vibrates ? done loads of tests been in 4 garages they canot pinpoint fault things i done changed wheels trackingwheel balancingchecked all joints no movementapart from slight movement in stearing rack not loads though? this is whats happening i go up the duel carageway its ok the car starts to shake front end put clutch in shake stops car runs smooth at all speeds with clutch in let cluch up its ok but as soon as i accelorate shakes again let accelorator off it stops had cluch checked said its fine the car seems to shake when i accelorate or labour it at a set speed main dealer had car 2 days and couldent find the fault sometimes it feels like the wheel is coming off has anybody ever had this problem ? please help i think i will change steering rack arms just to rule them out any more idears thanx mark
    Sounds like something's out of balance - could be the clutch itself maybe...? Not an expert, just a thought...
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Duel mass flywheel maybe?
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Bearing in the gearbox, Or as stated, If your Model has the Dual Mass Flywheel, That could cause it !!
    Dean
    great yarmouth
    Quote Originally Posted by Penfold101 View Post
    thanx for reply havent ruled it out myself yet
    great yarmouth
    Quote Originally Posted by DeanF View Post
    Dean
    thanks i know what the flywheel is how will i know if it has the dual mass flywheel /
    Oct 2007
    Sussex
    I used to have an old shape 2.0 DTi (99-T). That used to vibrate like mad on acceleration... and above 75 on the motorway. That turned out to be the input shaft bearings on the gearbox. Bearing in mind though, it was the F18 gearbox that's made of chocolate... not sure what yours has...? A new gearbox sorted it in the end, got a used one from a breakers for £250.
    It was also linkage rod actuated from the gear lever and the gear lever used to shake about aswell...awful...! Think yours is cable actuated so you might not get that.......
    I have just cured this exact same fault on a mate of mines 2.0 DTi "03" veccy turned out to be a drive shaft not bent just running slightly out of true so £40 from a scrappy and it's all fixed .......HTH
    great yarmouth
    Quote Originally Posted by GSiSnash View Post
    no gearstick doesent shake thanx for ur reply mark
    great yarmouth
    Quote Originally Posted by Drinky View Post
    this sounds promising could you have had the same fault i dont notice it at normal 30 mph speeds but seems the harder i accelorate and the faster i go the worse it gets but if i get it up to 90mph and put clutch in it runs smooth does that sound the same thanx for your reply mark
  1. Vibration and intermittent ABS Fault?
    By Chunklamb in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 12:49
  2. help needed to fault find (or read codes) 2.0DTi
    By FLOB in forum South East (ARO jaqubek)
    Last Post: 4th April 2012, 18:15
  3. A few of my garages ...lol
    By Morephun in forum The 'Off Topic' room
    Last Post: 14th November 2009, 19:23
  4. HELP have fault codes but still cannot find cause.
    By REDBULL1717 in forum Engine & Drivetrain
    Last Post: 29th October 2009, 20:00
