Thread: Should I transfer my dampers to my new car?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Should I transfer my dampers to my new car?
    I am getting the 1.9cdti 150 sri.
    I believe these already have shorter dampers than standard.
    I have Eibach sports dampers on mine with lowered springs (I know I will have to get new springs as its different axle weights).
    So should I:
    Change them over as they are less than a year old, the new car is a 2005.
    Leave the orginals on and change the springs.
    Any suggestions on springs?
    Currently been using PI springs on the 1.8sxi and coupled with the eibachs it is nice and low.
    [Ex]Admin Duncan's Avatar
    You may have a problem transferring the kit over from the 1.8 to the 1.9CDTi as the front axle weight of the 1.9 will be a fair bit more than than the 1.8 (you'd need to check). Assuming it is, then you'll be using the kit on a car with a higher FAW than it's intended for.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    These are dampers
    http://www.europerformance.co.uk/pag...html?id=446268
    It says they are also suitable for the 1.9 CDTI
    I know the shocks/springs will need to be replaced
    Quote Originally Posted by merikiito View Post
    Read the bl**dy thread properly Duncan!!
    Right, in reply to your question (now I've read it properly! ) I can't see why you can't swap the dampers over and then just get the springs you need. As long as you match up the springs with the dampers then you'll have a nice setup. Why not get Bilstein springs as they work nicely with Eibach dampers.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Looking for Bilsten springs as soon as I have done this post, cheers Duncan
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    EDIT-
    I'd better read the thread properly too, i'm cracking up.lol
    Oh for Gawd's sake - what's wrong with my brain this evening!!!
    Yep, I did indeed mean Eibach springs to go with his dampers!!
    Just realised, he said he has Eibach dampers, so Eibach springs should match perfectly. I think it was the Eibach dampers that threw me as I'm used to seeing that relating springs!
    I'm off to get my first glass of wine - might help my posting a bit! lol
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Cannot seem to find Bilsten springs, any ideas were you can get them from Duncan?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Going to be a long evening as this rate
    So are we saying it is worth changing every thing over then, there will be a difference compared to the standard SRi setup?
    I'd swap the dampers over but i'd get rid of the springs and get a set of eibach's. It should handle superbly after that.
  1. Ipod transfer help
    By aerodynamic18 in forum The 'Off Topic' room
    Last Post: 25th August 2009, 19:40
  2. reg transfer
    By cr0m81e in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2009, 17:19
  3. cherrished transfer...???
    By ROY2593 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2009, 09:17
  4. Transfer News
    By VauxVeteran in forum Comedy & Humour
    Last Post: 5th April 2009, 03:38
  5. HDD transfer Xbox
    By SteveH in forum Games Room
    Last Post: 17th March 2009, 18:37
