Thread: power in boot
    aberdeen
    Default power in boot
    Hi all, I'm looking to put a sub and amp in the rear could anyone tell me if there is a permenent live for the amp somewhere in the boot.I'vegot all the rest of the wiring in but forgot about the feed and don't want to have to take the head unit out again. I was thinking about the light in the boot.
    Portadown, N.I.
    Hi there, You dont want to take power from the light in the boot, it wouldn't be rated for enough currant and would only operate when the boot was open!!!
    There is a fusebox in the boot and it is possible to get a 12V feed from there. But unless the amp is quite a small wattage one, the best option is to install your own feed direct from the battery and have it fused to match whatever cable you decide to use. The heavier the cable feeding from the battery to the amp, the better your bass responce will be.
    Tim
    Portadown, N.I.
    Just found a link to where you can get the 12V feed from the rear fusebox.
    http://forum.vectra-c.com/showpost.p...70&postcount=6
    Hope this helps.
    Tim
    Jul 2006
    ^^^ what he said. None of the power wires in the boot will be anywhere near big enough to take the kind of current the amp will draw. Sorry, but you're going to have to take out your HU again.
    aberdeen
    Thanks put this is not the main power I have that staight from the battery is the remote wire that turn the amp on normly you use the automatic antenna in the back of the head unit. There is so many wires at the back of the unit it's a nightmare to get it back in the slot.
    south wales
    when i fitted an amp to my old car i was recomended not to run live and stereo leads down the the same side as they can interfear
    aberdeen
    Thats right the power at one side the sound at other.
    aberdeen
    Read the how to thread from parapaul you have it from the lighter socket in boot but I have hatch and don't have one
    Jul 2006
    Yeah....I did...
    If its only for the remote you could tap off the wiring for the boot light maybe?
    Portadown, N.I.
    Quote Originally Posted by parapaul View Post
    Yeah....I did...
    But wont that mean that the amp will only come on when the boot is open.
    Tim
  1. Power Boot Won't Close
    By Hursty103 in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2012, 10:22
  2. Power Socket in boot
    By DeeBe in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2012, 16:24
  3. Power in boot area
    By Handyandy-UK in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2011, 17:29
  4. No power to boot lock
    By bnam in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2008, 12:57
  5. Amp power/earth from boot
    By vectrasri03 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2006, 12:13
