Thread: Fuel filter + service light
    derby
    Default Fuel filter + service light
    Got a 2004 vec 1.9cdti due for service, just need help on how to change the fuel filter plus where can i locate the pollen filter an is that sumat that ahs to be changed. Also tried all the methods for re-setting the service light but no luck any other ideas. Each time i try to re-sett the servic light it just goes blank and nothing happens at all.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Pollen filter is on the right hand side (as you look into the engine bay) under the scuttle panel. Pull the bonnet seal from the rear of the engine bay, and there is a panel that lifts up. The pollen filter is under that, retained by a couple of clips.
    To reset the light, have you tried pressing the brake pedal and leaving the drivers door open whilst you press and hold the trip switch, and then turn on the ignition to position II (ie dash lights on). You have to hold the button for approx 20 seconds.
    Nicking Ya Dinner.
    If you change the fuel filter, top the new one up with derv before you close it up and start the car, helps keep the air out.
    south wales
    changing the fuel filter on a 2.0T i know its totally different but its a pain,theres only 2 littleplastic clips you have to get off,a tyre place let me use there ramps,they all got squirted with petrol,is there an easy way of doing it
    derby
    Default cheers
    cheers people for your help its helpfull. Anyone know where i can get hold of a haynes car manual for vectra's made after 2002 an plus the clutch pedal is very smooth but i have 2 liek bring it to my face before the car starts to move does that mean the clutch is warn out
    derby
    Default fuel filter
    once i attempt to do it the fuel filter once i can get hold of the part as allot of dealers say that most cars are still underwarrenty their aint mass production of service parts so have to wait till next week to get one will attempt it an let you know how to do it if no one els has suggested how to do it
    derby
    ps is when you put derv do your mean diesle
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Derv is just another name for diesel....system is self bleed but it will normally take a few seconds on the starter to get the air out and the engine running smoothly ...as VV says it is good practice to fill the filter housing with fresh fuel to help the process
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by mr.4dil View Post
    Anyone know where i can get hold of a haynes car manual for vectra's made after 2002...
    Halfords, local motor factors etc. not long been released, but at least it covers your engine.
    once i attempt to do it the fuel filter once i can get hold of the part as allot of dealers say that most cars are still underwarrenty their aint mass production of service parts...
    Eh?!!! Parts are easily available and in plentiful supply.
    derby
    Default parts
    I had trouble getting hold of the oil and fuel filter for mine, but being asian we go for cheap parts so have to wait longer . Should be getting it on monday
  1. Replies: 0
    Last Post: 24th January 2013, 18:50
  2. engine warning light after fuel filter change
    By webtrawler in forum Troubleshooting
    Last Post: 29th September 2012, 22:04
  3. service (fuel filter)
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 23rd February 2012, 10:51
  4. Engine Fault Light - Water in Diesel Fuel Filter?
    By rharris21 in forum Engine & Drivetrain
    Last Post: 14th February 2012, 10:06
  5. Fuel filter change!! service
    By kevinmc in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 00:15
