Thread: LED Lighting
    Oct 2006
    Wellingborough
    Default LED Lighting
    I noticed the other day that my work have just started advertising "automotive" LEDs, thought i'd get some and see what i could do on the LED hating Vec.
    http://uk.rs-online.com/web/generalD...utomotive_LEDs
    The festoon works fine in the boot and in the glove box, the T3's work for number plate lights and the front courtesy light (though the fade up/down doesn't work quite the same) and with no bulb warnings. I couldn't get into the illumiinated sunvisor to see what type of bulb it uses, nor the rear courtesy light, i would guess they are T1's, so should work fine as well.
    Next project for me is to try and make my own puddle lights, i'm hoping there's a supply in the door i can use, if not i'll have to run cables from the courtesy light all around the car
    What are you using for your sidelights mate?
    Oct 2006
    Wellingborough
    Just standard bulbs, i'll wait until they need replacing and then try LEDs.
    They'll jsut throw up all the usual warnings mate.
    Can't recommend these enough though:
    http://cgi.ebay.co.uk/MTEC-XENON-SUP...QQcmdZViewItem
  1. More lighting
    By kman247 in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2010, 22:14
  2. Lighting help.
    By MJG91 in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2010, 11:50
  3. Lighting
    By John LE in forum Part Numbers
    Last Post: 15th March 2010, 02:33
  4. gid lighting help!
    By vauxdude in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2010, 13:57
  5. New lighting
    By fenderguitar in forum Quick Photo Album
    Last Post: 6th May 2009, 21:42
