Thread: NGK Iridiums for 3.2
    Regular Member jamesr's Avatar
    Lancashire
    Default NGK Iridiums for 3.2
    I have got my plugs this morning: NGK Iridium IX part no. BKR5EIX
    I have read posts on here about wrong plugs etc.
    Are these correct for my 3.2?
    Don't want them hitting the pistons etc?
    Lancashire
    I have been told all they make are these: NGK--BKR5EQUB
    which are normal NGK's
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    This may or may not be helpful http://forum.vectra-c.com/showthread...ighlight=denso
    Then have a look on the Global Denso website and they do iridium plugs for the Z32 lump. I've serached for NGK Iridiums and I don't think they do the EXACT plug for the Z32.
    I think your second post is more likely to be your answer.
    I struggled to find NGK iridium plugs for my 3.2 Elite last year so instead i went for the Denso iridium plugs got a set of 6 for £46 all in from Euro Car Parts which i think is a bit of a bargain ...............P.s they are a crackin plug as well almost eliminated the flat spot these engines seem to suffer from !!!!
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Take one of the old ones out and compare it to your new ones if its the same length etc it will be fine.
    Lancashire
    Do you know how difficult it is to get at the spark plugs, not just a case of bein able to whip em out to check!!
    Aberdeenshire
    On the old V6 red top the first bank is easy dont know what the 3.2 is like never had a look at one cant be all that bad surley!
    Lancashire
    Can anyone else help?
    Lancashire
    Default Update to Iridiums
    I have been on the phone to NGK today and the NGK Iridiums DO fit the 3.2.
    The part number is BKR5EIX
    Hope that helps you all!
    Regular Member tommyk999's Avatar
    May 2007
    Oxford
    Hi,
    I called them today as well and they sad they fit but they do not recommend
    to do that. I better go for the DENSO then.
  1. Set of NGK iridiums for V6
    By jamesr in forum Parts for sale
    Last Post: 13th March 2008, 22:35
  2. Denso Iridiums
    By 2ltrT in forum Petrol Engine related
    Last Post: 4th April 2006, 21:40
