Thread: Front driver side spring noise
    Jan 2008
    falkirk
    Default Front driver side spring noise
    hi all,
    when i turn the car wheel staionary or at slow speeds i get a noise from D/S wheel, got mrs to turn and i then held the spring which was making the noise. a sort of groaning/stuttering noise,
    the plastic mods have been done any clues as to what?
    is there a bearing in the strut that can be greased or something?
    you can remove the strut and grease the top bearing if you have the kit to disassemble the strut..you can also clean out and grease the lower spring pan as well to help the spring move in the pan....both should cure the problem...my bet is the lower pan..
    Jan 2008
    falkirk
    cheers gsi
    you say kit so iam assuming spring clamps? to remove top where bearing is
    or just drop the strut & clean out out the lower spring pan(where plastic mod is)?
    yep, spring clamps..
    you'll need them to pull the spring up to get the groove under the spring cleared..then clean and grease it..
    it'll aslp let you pull the top bearing down enough to split the track and shoot some spray grease in there..
    Jan 2008
    falkirk
    cheers m8
    will give it a go, i know a m8 with a them,
    but what about, as a quick fix
    jack it up & give it a blast with pressure washer to remove dirt etc
    then spray in some lube?
    worth a shot?
    yep.. worth a go.....
    Jan 2008
    falkirk
    tried the easy way but still a noise as if the springs groaning & trying to turn.
    i take it this bearing alows for rotation & that is possible cause of the noise?
    just trying to get it right in head before dismantling
    Regular Member marcdale's Avatar
    May 2006
    Bristol
    Quote Originally Posted by barracuda View Post
    Yes, that's correct. Just done mine but for different reasons.
    http://forum.vectra-c.com/showthread...d=1#post496258
    My suggestion is to use copper grease in the top bearings because the ball bearings don't travel enough to move the grease around effectively. Copper grease (copper slip) doesn't congeal like normal grease in cold conditions. It maintains a more constant viscosity. The old grease in my top bearings was like a thick paste just pushed to outside of the bearing casing where it wasn't doing diddly for the ball bearings.
    Jan 2008
    falkirk
    yip done that m8, grease that was in there was thick N grainy, thought it would be a bit more sealed to stop that,
    many thanks all who replied
  1. Driver Side Fascioa Air Vent Noise
    By Merryterry in forum Vectra C / Signum Troubleshooting
    Last Post: 31st January 2013, 09:52
  2. loud whirring / hoover noise from front driver side
    By Drazek in forum Suspension, Wheels & Brakes
    Last Post: 2nd May 2011, 17:10
  3. Front driver side rattle
    By bizerk in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2009, 15:37
  4. Driver side door / Clicking noise
    By bizerk in forum Bodywork & Interior
    Last Post: 22nd September 2008, 18:56
vectra c noise on passenger side
