Thread: Anti freeze/ engine flush.
    Regular Member jamesr's Avatar
    Lancashire
    Default Anti freeze/ engine flush.
    There is loads of crap in my anti freeze reservior, what the easiest way to:
    1) Drain the engine? Disconnect the Rad?
    2) Flush out the crap?
    3) What do I top up the antifreeze with is it the red one?
    http://www.opieoils.co.uk/images/PRODUCT/medium/903.jpg
    just seen this one?
    1, engine.. remove waterpump...lowest point of the engine..
    Radiator..remove bottom hose..
    2, hose pipe down from the headertank..
    3, yes.. use longlife red antifreeze to GM specs..
    James..left invoices at work..will PM you tomm AM....parts ready and waiting.
    Lancashire
    Thanks mark. I really wanted the air box for tuesday. Guess thats not possible now? How easy is the water pump to take off then?
    tuesday should be fine..nextday delivery on monday = tuesday delivery....
    while you have the cambelt cover off it's an extra 4 bolts to take the waterpump off...it's exposed at the same time as the cambelt..
    you done a cambelt on a V6 before James?
    Lancashire
    No I haven't I Iam not brave enough to try it either!
    I like to look after my cars - so seeing as this car is new to be Iam goona be doin the:
    Pollen Filter
    Oil and filter
    Engine coolant
    Fuel Filter etc
    Hopefully getting someone to do the belt ASAP for me?
    Did you manage to get the filter box for me as well as the belt?
    yep...not a problem..next day order from VX..
  1. anti freeze help
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2012, 22:58
  2. anti freeze help please
    By amir2300 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th January 2012, 01:02
  3. Engine anti-freeze
    By jacko52 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th November 2010, 17:52
  4. Anti freeze
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2006, 21:24
