Thread: safe code on a ccr2006
    crewe
    Default safe code on a ccr2006
    Have just finally fitted a bt ck3100 to my vectra, but whilst trying to go through entering the radio code part am having a few problems, namely it's not allowing me to go past the 'safe' screen, and the unit is flashing it's lights
    According to the manual you
    1. switch on ignition - Done that
    2. switch off set - Done that
    3. Press AS and keep pressed - Done that
    4. switch radio on keeping AS pushed in until beep - No beep
    5. display shows Code -No code dispay
    everything seems to be wired up correctly, i'm sure this is a simple problem but they generally are the hardest ones to fix
    Sunny Dartmoor
    Got to leave radio on with ignition until you see ---- then you can enter code,but if you get it wrong you have to wait longer for ---- to appear again,so get it right first time,good luck......
    What exactly is appearing in the display? Do you not get CODE, followed by 10 ---- showing?
    crewe
    the actual display on the dashboard is switching between 'safe' and then the time and temp screen, i don't get to the part where it shows the amount of attemps left. Because the radio itself is flashing i can't tell when it's on or off, the dashboard display just keeps switching between safe and the temp
    Portadown, N.I.
    I don't know if the same problem afflicts the ccr2006, but on the ccr2005 (or is it the cdr2005? ) they have a comman problem in that the vol / power switch semi-fails in that it no longer responds to the pressing to switch on or off.
    With mine it took quite a forceful stab to switch the radio on while pressing the AS to get it to switch back on, and then it took a long time to beep so that I could enter my code.
    I now just leave the radio on all the time and just mute it when instead of switching it off.
    Tim
    crewe
    just done some problem solving and the problem begins when i connect part of the parrot cableing to the sot-078 connection, up to this point the radio is off, but as soon as (the power connection) on the parrot is fitted to the sot lead the problems begin.
    not entirely impressed with the sot lead anyway as when the connector blocks are connected, some of the wires are pushed out, then time is wasted making sure all the wires are back in
  1. Where do I get the "SAFE" code from?
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 11:39
  2. display safe problem how can I enter code ?
    By alek_vxr in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2012, 01:48
  3. SAFE code
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2010, 17:58
  4. CCR2006 - How Do I Enter the Code?
    By Jezzy in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2009, 03:04
  5. Astra radio 7 safe code !
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2008, 23:33
safe code ccr2006
