Results 1 to 10 of 22
Thread: Air Box MODs
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Question Air Box MODs
    So far I have tried:
    A) K&N panel filter in a standard box
    B) RIP SPEED steel mesh cone filter with and without an enclosing box
    C) K&N panel filter with a modified standard box to add another cold air feed
    I've found the latter to be the best so far (C), what have other people tried and what results did you get?
    I have the Airbox mod, top & bottom with a K&N panel filter, it has made a big difference to power delivery, dunno if the top end has changed but the flat spot has certainly been reduced, it is hardly noticable now, I think a cat back powerflow now and it`ll be breathing like it should ...
    Paul (vectra 2.0T) tried a K&N induction kit and then a K&N Panel Filter on his car and found the Panel Filter was the best option.
    I'm currently running with the Airbox Mod, K&N Panel Filter and Powerflow Cat Back (not forgetting the tuning box). I'm more than happy with the drive
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default Did you find that the exhaust made a difference?
    I was just going to get the centre box removed and a striaght through pipe to the standard back box fitted.
    Regular Member Damian's Avatar
    Market Drayton
    Excuse my ignorance, what a Powerflow Cat Back ???
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default Powerflow exhaust system
    powerflow being the manufactures name and the system replacing everything from the catalitic converter back (centre and rear silencers).
    It`s an exhaust mate, from the cat back, opens it out a bit, and in Alex`s case looks the mutts nuts as well ...
    Quote Originally Posted by Damian
    stainless steel exhaust system from the cat back made and fitted to your car
    there is a powerflow dealer in stafford damian i was quoted £250
    Market Drayton
    Quote Originally Posted by vectra 2.0 t
    Is that for a single branch exhaust. Have been asking ANDYVEC about the Irmscher twin dual exhaust system
    The irmscher exhaust is a cosmetic improvement, if you want some power at the same time then powerflow is the way to go. I was quoted £350 for a cat back with Quad pipes, that included cutting the rear skirt as well ...
  1. My Audi A4 with new mods and the mods since I got it!
    By sduk in forum Non Vectra C/Signum Album
    Last Post: 29th February 2012, 05:08
  2. Little mods
    By bigdave1701 in forum Styling
    Last Post: 7th September 2011, 17:56
  3. V6 GSi mods
    By RobHawkins in forum Petrol Engine related
    Last Post: 11th August 2008, 02:16
  4. Vec C LS Mods?
    By bizerk in forum Styling
    Last Post: 22nd July 2008, 01:20
box mods
