Thread: DPF Question
    Teesside
    Default DPF Question
    I am about to buy a CDTI 150 vectra (either new or no more than a year old) and am reading and hearing some bad reports about inlet maniflods, swirl valves and DPFs, so I was wondering
    1/ Has the inlet manifold/swirl valve problem been cured on later cars ?
    2/ is it possible to remove the DPF altogether from the exhaust system (in the way a de cat pipe would work)?
    3/ I would want to go for a remap up to 180 ish BHP and greater torque, is the gearbox man enough for the additional Torque ?
    Thanks Neil
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    88 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Hi Neil,
    I think You'll only get a dpf if you buy an estate or signum.. The gearbox will handle the increase from a remap with ease and i think the dpf has sensors on it, so if you remove it you may need to short out the sensor in some way or install the sensor into the new pipe.. as for the swirlpot / manifold i have no idea, but it didn't stop me ordering a new car or remapping it even though its now only done 514 miles... thats what warranty is for
    [Ex]Admin Duncan's Avatar
    If it's an auto 1.9, it'll have a DPF - even in the Vectra.
    As for removing it, as Pete said it's linked up to sensors so you can't remove the DPF without being able to tell the car that it hasn't got a DPF any more.
    Now this could be something that's possible. You can actually retro-fit a DPF (why you would want to is beyond me), as long as the car is specced to have the attaching points from new. So you can obviously tell the car that it has had a DPF attached, so you must be able to do the reverse. The DPF is part of the cat assembly, so not sure if you can just remove the DPF, or if you'd need to decat it too, or just get the front section from a 1.9 that didn't have the cat - i.e. what's on a manual Vec.
    Teesside
    So the manual cars do not have the DPF fited then?, it is a manual car I want to buy anyway so hopefully this will not be an issue for me
    Not the manual 1.9 hatchback/saloon. If it's a manual 1.9 estate or Signum, then yes it will, as will the auto 1.9 on the hatch/saloon.
    Regular Member shan's Avatar
    i think even if you did remove the DPF and got the car to accept it.
    It will give you emissions issue's at MOT time.
    A remap or tuning box will achive 180 bhp no problem and i'm sure the gearbox will take it.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by shan View Post
    Unlikely, as the MOT test for diesels is to free accelerate the engine from low to high idle, and see if you can still see the other side of the workshop through the smoke.
    Ethics of removing an emission cleaning device? now that's a different story.
    Teesside
    When all the smokey old buses, lorries and local authority vehicle are off the roads, I will start to fell a pang of concience for thinking about removing a device that is costly to replace, increases fuel consumption,strangles perfomance and engine efficiency, seems to give problems for ownwers, and is there as a result of an EU directive made to satisfy a bunch of "greenies" who want to tax us off the roads
    But there again I mourned the demise of two stroke motor bikes a few years ago
    As an aside is the vectra Galvanised ? just wondered because VX are only offering a 6 year anti perforation warranty
    Regular Member scottyd's Avatar
    paisley
    smokey old buses where? lol you'll love your 150cdt mate
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Our own little bit adds up if everyone does it.
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
