Results 1 to 10 of 21
Thread: OBD 2 can bus code scanner
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Default OBD 2 can bus code scanner
    Hi all, i would like a Obd 2 scanner, and have found heaps of
    them for sale on e-bay, i only really want to read the code
    and not mess about changing stuff, but i read some where
    that not all the scanners read all the codes !
    what is the best reader to buy, and what should i be paying
    for it ? i would like to get one before i take my car in to the
    stealers next week, i would like to be a few steps ahead if poss !
    Thanks now for any reply's
    cheers
    Kcs
    if you want one for engine codes, you can pick one up for £50 off ebay..
    if you want one to read ALL the codes on the car then you're going to be looking at around £500....
    owning a code reader is okay... but there's a whole lot more to understanding the faults than just reading the code..
    Feb 2007
    Tamworth
    Thanks Gsi, your right, there is a lot more than just reading the codes,
    my old man has got one for his Toyota Rav, and he had three fault codes
    that would keep coming up, two sensers and a cat fault, it was the coil pack that had failed after he had looked at just about everything ! you mentioned
    body codes to me on a previous post, so does that mean the big 500 then !
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Mine was £23 + post on Ebay
    Heres the guy i got mine from, make him an offer of about £20 to start with and he should come back with a offer of £23
    http://cgi.ebay.co.uk/Brand-New-U480...QQcmdZViewItem
    Works fine on my Vectra, you can reset the fault lights and delete the codes from the ECU once you have fixed the fault
    If you use it once then thats still half the price of a stealer
    That one will more than likely only read P codes.( engine codes)...I've only ever come across 4 or 5 tools that will read all the cars systems..
    Kcs..yep..if you want TOTAl access then it looks like the big £500
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    I understand it reads the same codes as the £50 readers, the only difference is they have a refrence for the codes built in and display them on the screen and also can read live data, but if all you want to to is pick up codes and reset the cheap one will do the job.
    so can your one read rear electrical centre and body control module faults then Deanos???
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Mark, the £500 one you mention is it an actual reader or is it the vauxcom software?
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Dunno, doubt it
    Im just saying the cheap one i got reads the same codes as the £50 ones
    it's Vauxcom...( a very powerful tool ) .. there are other systems that will access all the ecu's but they're touching upwards of £4k-£5K...even 'sykes pickivants' ACR4 is over £2k by the time you add the modules to do what vauxcom can do....
  1. U480 Fault Code Scanner
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2011, 13:48
  2. Code Reader / Diagnostics Scanner
    By r.bailey63 in forum North East RO Vacant - ARO - Vacant
    Last Post: 4th March 2010, 10:34
  3. Car diagnostic scanner code reader
    By s1nglef1sh in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2009, 19:33
  4. Car Diagnostic Code Reader / Scanner OBD2 CAN U581 2009
    By texaspete1973 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 21:27
  5. U581 Fault Code Scanner
    By robzc in forum Engine & Drivetrain
    Last Post: 8th December 2007, 14:48
