Thread: VW Style Alloys-would they fit.....??????
    Sunny Dartmoor
    Default VW Style Alloys-would they fit.....??????
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=007
    Like these alloys a whole lot and wondered if they'd fit the veccy,i know the stud diameter is slightly different,vx being 5x110 an 5x112,can anyone explain to me if they'd fit as would really like these on my car.......
    The other thing is why are alloys for the vectra/signum so much more expensive than for other makes,Bmw,VW,Fraud etc......
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    think they need be 5x110 mate..am sure someone will confirm..
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    dont think they will fit without havin the centre bored out slightly. vw's, iirc, have a smaller hub bore than vx.
    the pcd would be no problem, wobbly bolts can be used to fit them.
    Edit: cause they arent original VW alloys, ask the seller what the centre bore is. if its bigger than the vec's 65.1mm then all u should need to fit them is a set of spigot rings ( and the wobbly bolts).
    Sunny Dartmoor
    These could fit then............
    could do yeah.. dependin on centre bore.
    also just noticed the offset is ET45, the vec's recommended is ET35. im not sure on the min max limits.
    I used to have a set of 19's, 7.5" wide with ET45 and they were fine, they just sat inside the arch abit more.
    Sunny Dartmoor
    Thanks Carl,will get on the case,watch this space.............
  1. 18" VXR Style Alloys
    By Del101 in forum Photoshop section
    Last Post: 7th January 2013, 22:00
  2. New Style Key Fob?
    By PAD_D in forum Vectra C / Signum Troubleshooting
    Last Post: 11th October 2009, 21:27
  3. What style alloys?
    By Jackvectra18 in forum Styling
    Last Post: 22nd January 2009, 21:54
  4. 17" VXR Style Alloys for sale...
    By Penfold101 in forum Parts for sale
    Last Post: 20th October 2008, 13:16
