Thread: Power Steering problem
    Default Power Steering problem
    Parked my car the other day, having parrallel parked, the wheel was on full lock.
    Left the car for 10 minutes, went back, and when I fired up, I couldn't turn the wheel
    The power steering icon was showing, and belive me there was no assistance
    I couldn't manouvre the car out of the parking spot.
    I switched off and re-started, and it was fine, and the oil level is fine
    Any suggestions, it has been fine since.
    Feb 2006
    Nr Liverpool
    The same thing's just happened to me. The car was parked on the drive, started ok, put it into gear and as we pulled away I turned the wheel and "BINGO" the dreaded light comes on and no power steering. I turned the engine off then back on and all was well again. Dont know about you H11LGX but I'm getin on the phone in the morning, I dont like the idea of that happening on the motorway at 80mph going to and from work. Anyone got any ideas?, it must be an electrical fault for the light to come on I'd say.
    Just noticed the date you posted mate. Did you take your's back to have it checked out? if so did they tell you what was up? before I ring the garage in the morning.
    Thanks.
    I can only think it has something to do with the electro-hydraulic steering
    Sweden
    A glitch in the system
    Check it with Tech2, to make sure its no hardware problem.
    south wales
    hi guys and girls, can somebody help me with a problem? i have a 2.2 sri and the power steering has stsrted to feel heavy so i open the bonnet to look for the power steering fluid pot, but i cant find one. Ibought the car from a used car dealer but the manual was missing so i cant look it up.
    Regular Member cpt slow's Avatar
    In a house
    The fluid container is behind the drivers side front wing near the front. If you look down that area next to the radiator with the bonnet open you will see it .
    Mileage : 000
    Dread to think how you top it up though, must have to take the wheel arch liner off i would imagine.
    Bedfordshire
    Just read this Thread. I have a 3.2 GSI and i do need to top up the power steering fluid and i have been looking for it for little while.
    [Ex]Admin Duncan's Avatar
    Have a look at this thread guys. There's a reply I popped in (with a PDF) explaining how to get access to check/top up the PS fluid - not you should need to BTW, it's sealed system. If you're losing fluid then there is a problem.
  1. Power steering problem
    By Danwells72 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th October 2012, 16:25
  2. On Going power steering problem
    By gazspeight in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2011, 18:18
  3. power steering problem
    By mr.d in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2011, 22:33
  4. Power Steering problem
    By delete1 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2008, 20:41
  5. Power Steering Problem
    By llaregub in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2008, 11:35
vectra c steering problems
