Results 1 to 3 of 3
Thread: Testing Camshaft sensor V6
    Regular Member vecest's Avatar
    Felixstowe
    Default Testing Camshaft sensor V6
    Hi Folks
    Anyone know how to test a camshaft sensor from a V6 petrol? Obviously this is off the car due to a code31 (Omega 2.5 V6). Crank sensor was replaced 16K miles ago so suspecting camshaft sensor this time.
    Any thoughts?
    Mark
    if the crank sensor wasn't OEM VX then it could well be duff again..there are some dodgy pattern copies about....
    you need the camshaft sensor on the car and an ocsilliscope to check for a switching waveform..or just stump up for an OEM replacement....
    Felixstowe
    Thanks Mark - the new crank sensor was a Vauxhall part (Bosch) and the camshaft sensor is also. Dealer doesn't have one in stock but hopefully will have one at the weekend. Was hoping there might be an easy test.
    Thanks for your help though
    Mark
  1. HELP - where is camshaft sensor.....
    By sri150 in forum Engine & Drivetrain
    Last Post: 30th December 2013, 18:24
  2. Camshaft sensor Q?
    By Barlow in forum Engine & Drivetrain
    Last Post: 11th April 2012, 23:03
  3. Camshaft position sensor
    By disco dan in forum Engine & Drivetrain
    Last Post: 16th November 2011, 18:29
  4. camshaft sensor
    By lusk in forum Engine & Drivetrain
    Last Post: 6th March 2011, 19:30
  5. camshaft sensor???
    By evyboy in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2010, 17:18
