Thread: Diesel Additive for Vectra C Estate
    Cheshire
    Default Diesel Additive for Vectra C Estate
    Are there any diesel additive to stop the CAT from carboning up due to short ops?!
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Try "cataclean" can be used on petrol or deisel. It can be found on e-bay costs around £15 pounds a bottle.
    3.2 v6 Signum and loving it
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    Mileage : 198,500
    The Diesel particulate filter on the Vectra should regenerate itself automatically by injecting extra fuel to raise the temperature of the filter itself and burning off the deposits that have collected. You will probably notice a slight increase in fuel consuption if you have the fuel computer on an perhaps a slight loss in performance but it shouldn't be much. If the particulate filter does become blocked (short journeys can interrupt the regeneration process) the emissions light will come on to warn you. The system only regenerates itself when it detects an increase in back pressure, so there is no set timescale when it will kick in but on short journeys I would imagine it will be more regular. In theory a good blast every now and again should sort it without additives, Citroen/Peugeot use a pig derived additive which needs to be replenished on occasion and have a recommended replcement interval for the DPF, not something I'm aware of on the Vectra.
    Cheshire
    Thanks for the explanation
    As yet, no emissions light has come on
    Will give it a good blast from time to time as suggested
  1. modifications to 3 litre V6 diesel estate vectra
    By kop 76 in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 00:15
  2. Millers Diesel Additive
    By WeDesign in forum Diesel Engine related
    Last Post: 3rd March 2010, 20:48
  3. Looking at a Vectra C Estate - Diesel
    Last Post: 21st February 2010, 12:35
  4. which diesel additive
    By wardy in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2009, 20:43
