Thread: 3.2 back from service, 2 problems
    Regular Member Harro's Avatar
    Jan 2008
    York
    Default 3.2 back from service, 2 problems
    Hi there,
    This is my first post and need some advice.
    Bought a Vectra GSi privately just under 2 weeks ago, took it for a service today at local vx dealer. Couple of problems they picked up and price to fix:
    Oil leak from front crank seal £587.50
    Slight play rear susp bushes £321.95
    Do these prices seem reasonable, has anyone else had these probs?
    Thanks.
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Quote Originally Posted by Harro View Post
    Hi there,
    Thanks.
    By all accounts they are dealer prices & will always be expensive, At a good independant garage you will be able to save yourself £100's of pounds. For example the top control arm bushes ( Most likely what you have play in) are £26.50 Ea + vat from a good motor factors & take approx an hour to fit.
    I personally would get a well recomended garage to do the job.
    Dean
    Regular Member Steel's Avatar
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    I took mine in for a service last year, got charged the earth and they put a fault on for me! Next day after having it serviced the engine management light started coming on first thing in the morning. I rang them up and they said they would need it in for the day to check it out. Not wanting to spend another day in the 1.0 Corsa they lent me I plugged a new KTS200 in that we had on loan and it came up with a fuel rail pressure sensor fault/. I cleared the code and it never came back. My guess is after they changed the fuel filter and started it up it detected the drop in pressure and they never cleared the code.
    It's going in tomorrow for an new inlet manifold to cure the swirl flap problem and is due for service again but its not going back to the dealers for the service. As Dean said a good garage will save you a fortune and you will probably get a better service.
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    As someone i saw posted once, Warranty out, DIY/Independant Garage In..
    Hi there,
    Thanks.
    OMG!!!!...
    the front crank seal oil leak job is basically a cambelt change but you go a little further and remove the lower drive pulley off the crankshaft nose, then prise out the old seal and refit a new one.. adds about 1/4hr to a cambelt change..That quote is very very overpriced IMO..
    Rear Bushes..As DeanF said..more than likely the top arms which can be a g1t to change due to poor access, but even if it's the front tracking arms thats still quite dear..
    you need an independant VX specialist..steer clear of the main dealers as they are massivly overcharging you
    Regular Member j13hdb's Avatar
    Nottingham
    Cambelt at my stealer is £350 for a 3.2
    £350 + 15 min= £15 + part £10ish =£375 tops!
    Wonder why they're called Stealers? Find a good Vx garage (a family run one like Marehay are far better than these chains!) or an even better independent one!
    Jan 2008
    York
    Thanks for the advice guys, had the cambelt changed and oil seal replaced today at a local garage, cost £412.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    RESULT eh ??
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Hi there,
    Thanks.
    reasonable, me dont think so....
    Get a good indie garage mate. Check this site out for one http://www.goodgaragescheme.co.uk/ and save yourself some wedge.
  1. For all of your that suffer with back problems...
    By John LE in forum The 'Off Topic' room
    Last Post: 23rd May 2011, 21:05
  2. HELP! Car has come back from 40k mile service with no poke
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2010, 16:24
  3. different back box problems
    By mikey362 in forum Diesel Engine related
    Last Post: 5th April 2010, 21:43
  4. Back to standard but more problems
    By CNC in forum Engine & Drivetrain
    Last Post: 13th October 2008, 20:21
  5. well cars back after first service and.........
    By trucker in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2007, 23:17
