Thread: Household chores
    Regular Member Gaz the Cab's Avatar
    Nov 2007
    Chester
    Default Household chores
    I am doing a comprehensive redecorate of the entire house........well......at least I've started.
    I have some doors which are stained and then varnished, but, I want them gloss white, the question is can I just rub the varnish down and then put primer over the top or am I going to have to strip the varnish completely??
    Thanks.
    Mileage : 000
    I would have thought if you give the varnish a very good rubbing down so the primer/undercoat has some good surface to adhere to then you will be ok. I think lime dipping might get the varnish off but it will be more trouble to take the doors off and take them to be "dipped" I don,t know how much it would cost, or you could replace all the doors, That is what I did last year.
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    Just give the doors a good sand to form a key then apply 2 coats of white u/coat followed by 1 coat of white gloss, (oil based) You can sand in between coats but go carefull on the edges and make sure you dont sand through them (takes u/coat back off). You can use a 4" mohair roller to do panels styles and mullions then lay off with a brush to get rid of orang peel. P&D for last 26 years, good luck.
    Nov 2007
    Chester
    Quote Originally Posted by Gr4eme View Post
    Cheers pal.
  1. Replies: 9
    Last Post: 3rd July 2011, 11:43
  2. Another new car in the household...
    By soulman in forum The 'Off Topic' room
    Last Post: 24th April 2011, 21:27
  3. 2 vectra household
    By marichrd in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2011, 12:59
  4. Household interior doors for sale
    By gibbon7000 in forum General items for sale
    Last Post: 13th October 2009, 20:00
  5. Household Electrics- Kitchen
    By MuteJoe in forum General Chat
    Last Post: 22nd June 2008, 13:58
