Thread: AM2 Motherboard to overclock?????
    Apr 2006
    Quinton
    Default AM2 Motherboard to overclock?????
    Can anyone recommend a good am2 motherboard for overclocking??
    I'm particularly looking for one that allows, amongst the other features, HT multiplier changing - as I have been reading up that 250mhz with a 4x will give good stability on an AMD 4200+ X2.
    I would prefer to stay on air so will be leaving the core voltage alone as much as possible.
    Any recommendations??
    Nick
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    Right well i'm using a Gigabyte S Series board the GA-M55S-S3, running the X2 4200+ CHIP.
    The beauty with these S Series boards is the rugged overclocking abilities it has,it comes with over clocking software on board as part of the Bios,probably you'll know how much more stable this is to running a GUI based overclocking application(if you can get one to work!!!)
    I'm currently running the chip with no core voltage change at a steady 2246.5mhz or a total of 4493mhz to be fair if i wanted to i could easily take her upto the 5mhz point if i so wished but find the current overclock has given me nice performance increases whilst protecting the longevity of the chip,not that should be a problem either as i'm running the Gigabyte Rocket Pro cooling tower,fitted directly over the chip,and holding a temp of around 46c no matter what i'm doing at the time. I'm also running the Nvidia 7600gs over clocked with Riva Tuner.(would stay well clear of the Nvidia tuner!!) That is also air cooled,and with two steel ball bearing fans to the side and front of the case,it's kept well cool under the hood!
    And best of all it's quiet! lol
    I Cant speak well enough of these S-Series boards,they are so reliable,and if you do get to carried away with overclocking they can handle it no problem!
    Infact when i first started playing with the board I destroyed a hard drive whilst the board remained unscathed! lol Great stuff!
    Apr 2006
    Quinton
    Thanks for that mate,
    I will only consider bios based overclocking, as you say, proves the most stable.
    What options does the s series give for changing?? CPU multiplier, ref clock and ht multiplier are the areas I would want to tweak to start with.
    My aim - although specific hardware dependent is to run 240hz with an 11x cpu and ht 4x. to give 4800 mhz - i am led to believe this should be quite stable.
    Nick
    Regular Member simon5800's Avatar
    May 2007
    derbyshire
    i have the abit kn9 and find it to be very good and cheap. it has cpu clock, multiplier settings to change and ht frequency between 1x and 5x
  1. my q6600 overclock + delta fan
    By Даниил in forum The 'Off Topic' room
    Last Post: 4th May 2012, 20:20
  2. CPU and Motherboard FSB Question...
    By n_hudson in forum The 'Off Topic' room
    Last Post: 13th May 2010, 14:43
  3. MSi Eclipse X58 motherboard
    By bruceybonus in forum General items for sale
    Last Post: 3rd February 2009, 07:38
  4. Replies: 8
    Last Post: 13th December 2007, 21:46
