Results 1 to 10 of 17
Thread: 2 Issues - Advice please
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default 2 Issues - Advice please
    I have a Vectra CDTi 150 Auto, 55 plate 34,000 miles:
    Issue 1). when I first get in the Car switch the radio on without the key in sounds quite normal, If I start the engine the volume and Bass seemed to be quite a bit quieter until I adjust the volume level it appears back as it was previous, is this normal?
    Issue 2). Engine ticking over in neutral sounds quite a typical Diesel Engine, if I engage it into Drive (D) whilst obviously foot on brake the noise of the typical Diesel sound seems to be more exagerated, is this normal?
    Thanks in advance.
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    P.S. theres a slight crackle noise when I adjust the volume button
    Thanks in advance.
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    sounds like a loose wire and when starting the engine vibrations make it worse
    Feb 2006
    Guttedsville
    CD70 Navi?
    Quiet on startup is quite normal. The crackling volume control - just rapidly turn it up and down a few times, it'll soon sort it.
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by AndrewTi View Post
    CD70 Navi?
    yes ..
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Aren't there different volume settings for Ing on and Radio on with Ing off,
    Could be wrong ??
    Jul 2006
    Mexico
    Regarding problem one....might be do to the Volume/speed control....try to turn that feature off and see if that cures it
    Sorry the best that came to mind HTH
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default posted earlier but no replies ...
    my Engine ticking over in neutral sounds quite a typical Diesel Engine, if I engage it into Drive (D) whilst obviously foot on brake the noise of the typical Diesel sound seems to be more exagerated, is this normal?
    Thanks in advance.
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by BlueRob View Post
    where would I locate that feature?
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    sounds like the thrust bearing ?
  1. MPG Issues
    By skip85 in forum Engine & Drivetrain
    Last Post: 25th January 2013, 11:02
  2. key issues
    By purple170503 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th June 2011, 08:10
  3. Anyone on O2 having issues?
    By Ziggy in forum The 'Off Topic' room
    Last Post: 24th November 2010, 22:14
  4. Advice on safety issues with self repaired brakes.
    By ectraz in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2009, 11:23
  5. PC Issues
    By GazVXLINE170 in forum General Chat
    Last Post: 29th November 2007, 20:00
