Results 1 to 10 of 14
Thread: Can anyone tell me what all this is?
    Regular Member Dave1.8's Avatar
    Oct 2007
    Ellesmere Port
    Default Can anyone tell me what all this is?
    I have the CD30, if I press and hold the setting button, a beep is heard. Then if I press the button on the right on the screen, I can scroll through some info. I have written it all out below, what does it mean? thanks.
    HW: D1.50
    26.08.2005
    SW:4176a/0
    24.06.2004
    DD:4.B/6.0
    Code: 001/01
    LS:FF010000
    MS:4200
    Dimm:None
    0.0 100 100
    LCD: 34 C
    U30: 12.4 V
    RDS-T:11:35
    PI-EHU: OC
    Sens.: 9.5
    V: OT : 73
    spoons
    Guest
    Co-ordinates for the 'mother ship'
    They will come...
    Feb 2006
    Guttedsville
    Nanu Nanu!
    Oct 2007
    Ellesmere Port
    Ha ha!
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    it's just diagnostic information, depends what button you press after you have held down the settings button (looks like radio info?).
    Oct 2007
    Ellesmere Port
    Quote Originally Posted by lofty View Post
    Tha last one tells the cars speed in kph, like a second speedo
    Oct 2007
    Ellesmere Port
    If I was doing 50kph it would look like this V:50 OT : 73. The OT is the temp. I just wanted to know what all the others are.
    Oct 2007
    Ellesmere Port
    Anyone on here know?
    No idea. The CD70 one has so many pages of information it's unreal. Even gives you the actualy outside temp at the sensor, and then what it's displaying on the screen, and also the actual temperature of the engine coolant.
    Also shows the temperature of the LCD screen, for some bizarre reason.....
    Oct 2007
    Reading
    Vehicle : SAAB 93 Estate, Vectra C Estate
    Trim : LINEAR SE, Elite
    Engine : Z19DTH, Z22YH
    Year : 08,08
    Bit of guess work but years in the electronics industry I would suggest:
    HW: D1.50 Hardware revision / version
    26.08.2005 Date of hardware version
    SW:4176a/0 Software / firmware version
    24.06.2004 Date of software / firmware version
    DD:4.B/6.0
    Code: 001/01
    LS:FF010000
    MS:4200
    Dimm:None, No extra memory?
    0.0 100 100
    LCD: 34 C
    U30: 12.4 V 12V supply actual voltage
    RDS-T:11:35 RDS derived time
    PI-EHU: OC
    Sens.: 9.5
    V: OT : 73 see other replies
vauxhall vectra pi-ehu: of
u30 vectra c
corsa code 00101
corsa c lcd code:00101
