Results 1 to 10 of 17
Thread: filter mod
    Regular Member copperdock's Avatar
    Nov 2007
    leicestershire
    Default filter mod
    Hiya everybody did the airfilter mod today and found the how 2 very informative,reading through the how2 discusion i came to page 6 and 1 member said he would have to reset his ecu but he has also done the caterman mod so would he be refering to that for resetting the ecu. I:m sorry if this is going over old ground but if i dont ask i will never learn any information would help tony
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    resetting the ecu is done by disconecting the battery for about 30 min's and then reconect it, the ecu is a learning thing, so clear's out old data and keep's the new once you start to drive again......afaik good for all kind's of mod's like box mod/airfilter change and of course the box of trick's fitment...
    hth
    Midlands Mod Shop - NFFC.
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    From what I understand Its better to reset the ECU but not a necessity. If you reset the ECU it takes less time for the Air/Fuel ratio to be spot on as you should be drawing in more air , did you replace the filter at the same time ie with a K&N?
    balls too late
    Nov 2007
    leicestershire
    Hiya pecojess no i didnt replace the filter at all just cleaned the old one and put it back ,i ran the car round to the stealers in leicester for anew pollen filter and i got some discount on that which surprised me. i dont know if its my imagination but i thought the car pulled away alot better it being an oil burner
    Trim : Get a
    when i first fitted my box and K&N fliter i didn't reset the ecu, when the car went to te dealer's for some work the box came off.....got it back...re-fitted the box and reset the ecu..........and such a difference
    Nov 2007
    leicestershire
    Hiya ditchp i:m abit worried about messing with the ecu and electics in general on cars as i have not done this before and i:ve certainly not owned an oil burner tony
    Trim : Get a
    this is my first diesel too mate, trust me all it does is reset the air/fuel mixture..........doesn't upset the car in any way shape or form and you can tell the difference, just feel's smoother
    Nov 2007
    leicestershire
    Thanks ditchp and pecojess for the input on the post i shall see if i can sort somthing out tomorrow if the weathers ok.By the way i used tobe a NFFC fan in the glory days when i lived in Long eaton tony
    Trim : Get a
    used to be a forest fan.............once a fan alway's a fan mate......
    any luck with the reset ???????
    Nov 2007
    leicestershire
    Yes i know what you mean by always being a fan i dont take to much notice of football these days to much todo and not enough time,didnt have time todo the reset today had to go into work(mallory park) to have a look at all the mods they are doing before the race season starts,maybe i will beable to do it sometime before the weekend tony
  1. Oil filter
    By nokiaman1978 in forum Engine & Drivetrain
    Last Post: 24th April 2012, 20:40
  2. Standard air filter or K&N Panel Filter
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 15:38
  3. changin oil, oil filter air filter and plugs any handy tips!!
    By wallace78 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 15:04
  4. Air filter
    By Deano.56 in forum Engine & Drivetrain
    Last Post: 13th July 2009, 21:17
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
