Results 1 to 10 of 13
Thread: Resetting the ECU
    Regular Member wstwatson's Avatar
    Oct 2007
    wales
    Default Resetting the ECU
    If fit a K&N panel filter do i need to reset the ECU for better performance
    it will help the ECU and air flow meter adapt quicker..
    Jan 2008
    Telford
    resetting ECU?
    disconnecting the battery for a period of about 5 mins to reset all the ECU settings to factory defaults..
    Jan 2008
    Telford
    what about the radio codes?
    Larkhall
    i didnt do this - is it necessary?
    Quote Originally Posted by Cragy View Post
    should stay stored....if not just reprogram the set..
    never yet had one that lost it's backup memeory..
    Quote Originally Posted by T4M View Post
    not 100% necessary no..
    Larkhall
    I didn't think changing an air filter had anything to do with the ECU.
    it changes the air flow meter readings a bit as the K+N is free'er flowing..
    it won't harm it Tam.. it'll just want a bit longer to get the fuelling 100% again.
  1. what does resetting the ecu do
    By justin32 in forum Engine & Drivetrain
    Last Post: 6th January 2013, 23:12
  2. key fob resetting
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2012, 20:48
  3. Abs resetting
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2012, 12:05
  4. Resetting the ECU
    By kamar in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2010, 12:49
  5. resetting the ecu
    By lee_eardley in forum General Chat
    Last Post: 6th September 2007, 11:55
