Thread: CD70 code
    Regular Member wstwatson's Avatar
    Oct 2007
    wales
    confused CD70 code
    I dont seem to have the code for my unit how can i retreive this
    Jul 2006
    Mexico
    I think that model requires to be pluged to a TECH II and feed the code that way, which means a trip to a dealer or some garage that handle do the job via TECH II.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    The CD70 does not have a code; it is paired to the car/display via the car/security code.
    Oct 2007
    wales
    Default Cd70
    Where will i find the code
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    The car 4-digit security code is on your car pass, but you don't need it. It is only needed if you want to install a new CDxx unit or display
    Oct 2007
    wales
    Default Car pass
    I cant find the car pass, but if want to disconnect the battery will the code need re-inputting
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by wstwatson View Post
    no ! the CD70 does not have a code: the car knows 'his' CD70 and won't forget it, even not when you disconnect the battery.
    A code is only needed if you want to 'unpair' it (divorce), for instance if you want to sell the CD70 otherwise it will be useless
    11 Post(s)
    Regular Member shan's Avatar
    But you need the car pass " code" for the Tech 2 to be used. The Tech 2 guy needed mine when he did the foglights and the DPF burn.
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by shan View Post
    The guy probably needed the VIN and was to lazy to look for it elsewhere... however the security code is indeed needed for some tech2-sessions
  1. Cd70 code index?
    By markymarky in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 20:26
  2. no security code for cd70
    By pipamish in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2012, 02:14
  3. Vectra cd70 without code
    By pipamish in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2012, 12:55
  4. cd70 code
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2011, 11:49
  5. CD70 Radio code
    By bgm46 in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2008, 02:14
