Thread: CDR 2005 VDO Problems
    Doncaster
    Default CDR 2005 VDO Problems
    Hi
    I have a Subwoofer pack from my old car and am wanting to wire this to the head unit.
    Is the plug under the ashtray a diagnostic socket or related to audio?
    Also, I have removed the 4 grub screws from the front of the unit and am unable to remove the unit to have a look.
    I have a nasty feeling that the CDR 2005 VDO does not have RCA Sockets or whatever they're called.
    Is there any way I can wire up a powered sub without damaging the head unit?
    Thanks very much
    Chris
    Regular Member GoldenWonder's Avatar
    Durham
    Well I can help with a couple of those:
    The plug is the diagnostic socket.
    Removing my CDR2005 was a complete swine. I removed all of the surrounding switch blanks and storage trays and still could budge it!
    Eventually I removed the radio fascia and put my fingers inside the radio chassis and pulled like mad - then it popped out!
    On the back theres just the ISO connectors and aerial socket.
    Regular Member dazbluecav's Avatar
    Hampshire
    thanks for info - I've got a CDR 2005 VDO as well and i'm considering pulling it out as will persist in damaging my cd's!
    If i pull the CDO 2005 out, how do i keep the use of my steering wheel controls with a new improved radio/cd? Will the ISO connector on the car wiring harness take care of it with the new radio?
    Regular Member rmt's Avatar
    Cambridgeshire
    You'll need to buy the correct wiring looms, they're around £30
  1. 2005 2.2 radiator to fit a 2005 1.9 cdti 120bhp
    By IRvectra786 in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 08:59
  2. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  3. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  4. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
cdr 2005 vdo remove
