Thread: water in driving lamps
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Default water in driving lamps
    while i was replacing my head lights today i noticed that my inside driving lamp was full of water .what i would like to know is :-
    a is this a common fault with vec-c /signums
    b has any one come up with a cure
    regards bob
    Aug 2007
    Leicester
    My nearside foglamp is also full of water/condensation (car 4mths old).
    Took it to the dealers couple of weeks back to ask about it.
    Man on service desk said vauxhalls stance is:
    "If you can turn it on, the condensation dissappears and doesn't return, then they won't replace under warranty. If condensation reappears, they will. "
    This is a bit strange, as if you had turned it on and the condensation had dissappeared, you wouldn't be in the garage complaining.
    I said it returned after running it with it on, so he ordered a lamp.
    I believe this is a very common problem.
    You don't say what age your car is, but if it is out of warranty, I think the cost of a new lamp is quite a lot. It is a sealed unit, so I don't know of a fix, other than replace. It is probably a bumper off job too.
    very very common..
    if it doesn't burn the condensation out in under 20 mins and you have warranty then theyll swap it..
    i just stick a small packet of silica gel in the cap and that keeps mine dry..
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Clearly water is getting in there somehow.
    Firstly remove the bulb and get a hair dryer and CAREFULLY dry it out, you need to get some air flow into the unit too, it's helps a lot.
    Then you need to look at obvious water entry route, most common is through the cover, check for damage, ill fitting etc.
    If the actual seal to the front 'glass' is defective, that's more tricky, prob best to get a replacement, either under warranty or dismantlers.
    I'm assuming you mean main lights and not fog light
    Regular Member j13hdb's Avatar
    Nottingham
    Blatantly says fog light!Mine is like this- I undid the cover and had half the river I'd had to drive through cause of the floods land in my eye! Sneak the Mrs' hairdyer out and remove the bulb and blow warmly for 10 mins!
    Think mine comes from the cap so put some silica in for next time!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by j13hdb View Post
    Post#1 DOES NOT mention which light, part from 'driving light' - which I assume to be the main head light. Post#2 mentions foglight, but he is not the originator of the thread. Maybe you should read it again .
    I could be wrong, or I could be right - who knows....
    Nottingham
    I am not worthy and I alpologise
  1. Driving lamps
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 26th August 2011, 20:14
  2. Replies: 2
    Last Post: 28th July 2011, 13:37
  3. limp mode on motorway driving.....driving me crazy!
    By big rich in forum Diesel Engine related
    Last Post: 27th August 2010, 05:24
  4. Sri Driving Lamps - condensation
    By johnmac in forum Bodywork & Interior
    Last Post: 28th December 2007, 19:09
  5. AA driving school car + dangerous driving: Who to report to?
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 18:05
