Thread: K&N filter
    Jun 2007
    Black Country
    Default K&N filter
    Im servicing my bike this weekend, its got a K&N filter ftted and hasnt been touched in 3 years, how do i go about cleaning it, do i need any special oils?
    Here, there and every where!
    A quick search on google Amazing what you can find
    http://www.knfilters.com/cleaning.htm
    Larkhall
    My filter arrived this morning Won't be able to fit it till Thursday.
    Sorry to hijack the thread but which way does it go in??
    Either way round but it will only fit one way up
    Jul 2006
    Any idea how long they take to dry after washing? Got visions of being stuck with a wet filter on the draining board and a car u/s on the drive!
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    what ever u do do not get the filter wet. the only way to clean it is with an air gun and you have to blow them clean. i washed mine in water and i had power loss my oil was frothing in my view glass. not a good idea and i even let the darn thing dry over night. not sure if the k&n are the same as normal filters (material wise) tho, but i wouldn't risk it again.
    Nov 2007
    telford,
    just read http://www.knfilters.com/cleaning.htm and forgot k&n's aren't the same materials are they. ignore previous reply then guys. ooooops
    Regular Member beefycol's Avatar
    Nov 2007
    telford
    i used brake cleaner stepdad a mechianic n he said it the best way to clean to filter
    Scotland
    Quote Originally Posted by Guyver1 View Post
    K&n say it should be checked after 50000 miles for road use mate , so might not need done if youve not done too many miles.
    From their site :
    Quote:
    4. How often do I need to clean my K&N air filter?
    If you have not experienced a decrease in mileage or engine performance, chances are your filter is fine and does not yet need cleaning. To be more specific, the filter does not require cleaning if you can still see the wire screen on the entire air filter regardless of how dirty it may appear. When the screen is no longer visible some place on the filter, it is time to clean it. When used in normal paved road, street or highway conditions, our replacement air filters that fit in the factory air box should require cleaning every 50,000 miles and our large conical filters on an intake system should require cleaning every 100,000 miles. When used in dusty or off-road environments, our filters will require cleaning more often. We recommend that you visually inspect your filter once every 25,000 miles to determine if the screen is still visible.
  1. Oil filter
    By nokiaman1978 in forum Engine & Drivetrain
    Last Post: 24th April 2012, 20:40
  2. Standard air filter or K&N Panel Filter
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 15:38
  3. changin oil, oil filter air filter and plugs any handy tips!!
    By wallace78 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 15:04
  4. Air filter
    By Deano.56 in forum Engine & Drivetrain
    Last Post: 13th July 2009, 21:17
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
