Thread: Advice please
    Regular Member Dave1.8's Avatar
    Oct 2007
    Ellesmere Port
    Default Advice please
    Hello, can onyone tell me where the towbar wiring plugs are? I meen the one that you plug the VX harness into. Also, what exactly does the harness consist of? thanks Dave
    Portadown, N.I.
    They are located at the fusebox in the boot on the right behind the little door. Well, to get at the trailer wring socket and the trailer relay socket you ideally need to remove the rear passenger side panelling in the boot, but you can just see the sockets by opening the little access door to the fusebox and gently pulling the panelling on the side nearest the back seats away.
    The GM wiring kit I got consisted of a relay box thingy that plugged into the boot fusebox, and the actual trailer wiring consisting of a 7pin trailer socket wired up to a length of cable terminated in a plug the plugs into the REC ( fusebox in the boot)
    Tim
    Portadown, N.I.
    Oh, forgot to add, I didnt need to get it Tech2'd, it just plugged and played, although I dont have the trailer warning buzzer or the little trailer telltale light on the instrument panel.
    Tim
    Oct 2007
    Ellesmere Port
    That is just what I wanted to know! thank you m8
    Portadown, N.I.
    You're welcome, always glad to help.
    I think there's others on here that have fitted the 13pin trailer electrics, hopefully they'll tell you what there system looks like.
    Tim
    Feb 2007
    Glasgow
    If you remove the trim in the boot, you'll find this...
    I'm sure somebody will be able to tell you where it plugs in.
    The socket on the far right is where the trailer module plugs into.
    Oct 2007
    Ellesmere Port
    Thanks Duncan!
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
