Results 1 to 10 of 17
Thread: The dreaded spanner light
    Regular Member Finty's Avatar
    Jan 2006
    Ireland
    Default The dreaded spanner light
    The spanner indicator came on my car this morning for a few seconds and went out again. It does this every thing I start it. i checked the oil and it was pretty low so I topped it up. Questions are
    Does low oil level cause the spanner display to come on
    If topping up the oil has sorted it how long does it take until the spanner display goes away
    cheers
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Quote Originally Posted by Finty View Post
    cheers
    Hi.
    Is your car a Diesel ?? Has it started with the cold weather ??
    My Guess is Faulty Glow Plug/Plugs.
    Dean
    Jan 2006
    Ireland
    Quote Originally Posted by DeanF View Post
    Hi.
    Dean
    Yes its a 1.9 CDTi 150. Weather here is actually a bit milder than of late. Last week was a lot colder and i had no issues.
    The oil level was pretty low though. Was down at lowest level on dip stick. I had to add a litre to bring it back up.
    Are you sure it's not the service indicator matey?
    Full Member Big Sig's Avatar
    If it is a fault light, its showing it has recorded a fault but its not an active one or it would stay on. It will go out after 25 starts if it no longer has the fault
    Nov 2007
    Staffordshire
    I did get the spanner light illuminating after the car had stood for a few hours on colder days, Which led me to believe it was my glow plugs, I changed them & it never came back...
    The only sure fire way to be certain is to get the Code read & put your mind at ease !!
    You can buy a cheap code reader for £29, it may not give you a code for all the errors, But it will allow you to remove the error. If it then comes back straight away you know it is a current fault & not a historic one.
    http://stores.ebay.co.uk/LONELEC_W0Q...4Q2em158QQtZkm
    Dean
    Portadown, N.I.
    H mate, when your engine's low on oil it usually puts up a little pic of an oil can with an indication telling you its low, on mine it comes on exactly when the oil's at the Min line on the dipstick. But the car usually doesnt put the oil low indicator on until the car's been running for a while, or at least it doesnt on mine.
    Whereabouts are you? If you're close to portadown I may be able to read the codes for you.
    Tim
    Jan 2006
    Ireland
    Quote Originally Posted by spuddevans View Post
    Tim
    In Dublin. Thanks anyway mate. Its not using the service indicator service schedule but rather every 15k klms. When I check the service indicator it still shows 27k to go.
    Its due a service however in the next few weeks so I'll get them to check the code as well. Hopefully its nothing expensive
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Tim
    Tim,
    Any chance you could sort a Newry boy with getting codes read?
    Portadown, N.I.
    Quote Originally Posted by Stevie-B View Post
    Tim,
    PM sent
    Tim
  1. The Dreaded Spanner Light
    By alhambra in forum Engine & Drivetrain
    Last Post: 13th November 2011, 11:31
  2. Dreaded spanner light
    By gnomes in forum Engine & Drivetrain
    Last Post: 17th December 2010, 13:59
  3. Dreaded spanner light
    By Corey in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 00:58
  4. The dreaded spanner light :-(
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2008, 21:00
  5. dreaded spanner light when accelerating
    By formby in forum Engine & Drivetrain
    Last Post: 6th May 2008, 22:21
