Results 1 to 10 of 16
Thread: Now Iam worried.......HELP!
    Regular Member jamesr's Avatar
    Lancashire
    Default Now Iam worried.......HELP!
    I have just been out to change the HID bulbs on my new vectra, and thought i would have a quick nosey round.
    Its a 3.2 GSi
    1) The coolant bottle is orange and is covered in like a rusty sludge?
    2) Pollen filter is completely black - easy change this
    3) MOST WORRYING! The engine filler neck is filled with saled cream like sludge? I hope this isnt the head gasket? I have had no loss of coolant?
    HELP
    DON'T PANIC..
    the filler neck is totally normal.. cold air is hitting the oil mist and causing the mayo to form..
    I always take the neck extension off and put the fillercap straight onto the cam cover instead.... no more mayo appears..
    Pollen filter.. doddle.. nuff said..
    Coolant should be orange..thats the longlife stuff...if it's staining outside the bottle ( like it's overflowing) it could well be a dodgy pressurecap...got a piccy to show us what the bottle and it's contents looks like?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    sound like oil and water mix which indicats head gaskets im afrade
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    ????? no idea on the sludge
    yep
    common prob nothing to worry about remove the filler neck just twists off.
    Quote Originally Posted by glynn View Post
    it's a 3.2 design failing....removing the neck sorts it usually...
    Lancashire
    The bottle is not leaking at all, the inside of the bottle is coated in rusty sludge, where the return is from engine/rad, if you stick your finger in the inside is just rusty sludge.
    I will try and get some pics up?
    Thanks GSI 3.2 you put my mind at ease!!
    PS Where is the oil filter on these? front or back?
    Mileage : 000
    Short journey,s cause the "gunge" in the filler neck. A good clean out then it will be ok for a while, or as Mark [gsi3.2] say,s remove the filler neck and put the cap on in it,s place.
    oil filter.. down the front in an alloy canister.. look down between the exhaust manifold and the gearbox, look around the level of the top lambda sensor..
    Lancashire
    Thanks mate!
    Is it the paper ones where you change the element?
    yep, change the element and the o ring on the lid of the can....
  1. seriously worried
    By mikecoz in forum Engine & Drivetrain
    Last Post: 29th January 2013, 23:17
  2. Bit worried, might be over nothing!
    By george1987 in forum Engine & Drivetrain
    Last Post: 7th April 2010, 21:29
  3. Now i'm worried
    By braveheart in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2010, 10:26
  4. Should i be worried?
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2010, 22:41
  5. Bit worried
    By SRIRob in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 20:03
