Results 1 to 10 of 19
Thread: Sooty Tailpipes....
    spoons
    Guest
    Default Sooty Tailpipes....
    Since I moved over to Petrol cars, I expected to lose the 'sooty' tailpipes that you get with Diesels.
    However, I have to say that the VXR is just as sooty as the Diesels (and no... I'm not putting Diesel into it)...
    Is this normal ?
    member of the smoke patrol 230bhp+
    well now then steve your car is sucking the rubber hoses into the engine with that much power ,,so i think with all the hoses getting eaten by the 300eds,, a bit of rubber hose fired out the back is to be expected
    spoons
    Guest
    Quote Originally Posted by chrisgettings View Post
    Must be that then...
    Mileage : 000
    Or you are not driving it hard enough.
    Mine stopped after the remap, before that they were black .. The new car with a DPF has no soot, none, and it`s a deisel !!
    Nov 2007
    Sweden
    Turbo cars "should" have sooty tailpipes otherwise you drive like an old lady. (Petrol that is)
    So sooty tail pipes is perfectly normal and I would be more worried if they where not.
    Which reminds me, I have to polish the tailpipes and put som wax on them
    Yep, mine was driven like an old lady ... Thats why I had a Remapped 2.8T *lol*
    Leicester
    Steve, you may find that it is running a little rich, especially on full power, you will find that alot of the time mappers ensure they do run a little rich is will add a little protection to the engine.
    If you run lean, on full power it leads to detonation and melting pistons. My Zafira could be like that at times, I would not worry about it.
    When new, they also have wax all over them, so any crap will stick like glue, give them a good clean and polish as suggested above and you may see a marked improvement.
    Regular Member ion's Avatar
    walsall
    Yes Steve, this is a common problem.
    Unlikely as it seems, it can be caused by having a small object wedged in the bootlock mechanism.
    It seems to occur on debadged cars for some reason.
    I'd dismantle it just in case!
    HTH
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    you need one of them flame kits to burn all the excess soot off... apparently works a treat....
  1. Sooty exhaust tips - Y30DT
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 23rd November 2011, 22:54
  2. Replies: 13
    Last Post: 13th March 2011, 00:50
  3. vxr tailpipes ???
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2010, 19:13
  4. Sooty
    By Blagmeister in forum Engine & Drivetrain
    Last Post: 22nd January 2009, 00:54
  5. Sooty EGR Valve
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 20th December 2008, 19:49
