Results 1 to 10 of 13
Thread: Filler
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Filler
    Will filler go hard without the hardener mixed in? Even after prolonged periods of time?
    [Ex]Admin Duncan's Avatar
    Car bodywork filler?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, sorry should have been more specific.
    Also, what about if you don't mix the specified amount of hardener, does it just take longer to cure??
    In reply to your first question, I would think it would dry out ultimately once exposed to air - so would, in effect, get harder but probably quite crumbly.
    Re hardener - I'd expect it would take longer to cure, but it also wouldn't set as hard as it would've with the correct amount of hardener, so will remain 'soft'
    scotland
    i'm sure it wont have the same strength as if used with hardner .
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    thanks
    Regular Member EURO G's Avatar
    n ireland
    filler will not go hard when left for a long period it will dry out slightly,you need the hardner to cause the reaction which generates the heat which make isopon go hard,if you use slightly less hardner then it will eventually go hard we would use that method when the weather is very warm or if we have a large area to cover
    Nicking Ya Dinner.
    iirc the less hardener you mix it with the quicker it goes off, it is nearly 27 yrs since I used the stuff but I'm almost certain this is the case. hth
    other way round....more hardner = faster cure time and less time to get it on the panel and shaped before it starts to set..
    Nicking Ya Dinner.
    I knew it was one or the other, like i said, long time ago, and I don't miss it
  1. Best Oil to use and where does it go(apart from the oil filler)
    By caravaner-tony in forum Engine & Drivetrain
    Last Post: 30th August 2010, 21:23
  2. Oil Filler Cap
    By LOCKSTOCK in forum Engine & Drivetrain
    Last Post: 12th July 2008, 12:53
  3. how much is a filler cap?
    By corman in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2007, 22:14
  4. Where to get a new filler cap?
    By Lloydy in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2006, 02:07
  5. Filler Cap
    By MLC in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2005, 08:07
